Winter Hardwood Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 03:10 PM   #1
Rewards Points: 150
Winter hardwood installation
The 10-year old hardwood floor in my house gets small gaps every winter from the dry climate. Does this mean if I install hardwood floors (in another room) in the winter - the boards will push together and buckle in the summer because of the humidity? ie Should I wait until spring to install (I'm in NC avg. low right now is mid thirties).
joemontana16 is offline   Reply With Quote
Old 02-10-2010, 04:04 PM   #2
Remodeling Contractor
just let the new boards acclimate in the room for about three weeks and you will be fine.
Old 02-10-2010, 06:01 PM   #3
Civil Engineer
Rewards Points: 4,792
The key to avoiding the problem of buckling is acclimation (as mentioned by Bob), proper installation using manufacturer approved techniques, and installation using a manufacturer recommended gap around the edges. The gap is covered by molding, the required size of the gap depends on the size of the floor, type of wood, and relative humidity variation anticipated over the course of a season. There is very little you can do to prevent gaps in the winter short of humidifying the house, however gaps add character to the floor. Buckling on the other hand is serious trouble, and is avoided through proper design and installation.
Daniel Holzman is online now   Reply With Quote
removing baseboards for hardwood flooring installation amsanch72 Flooring 4 10-16-2009 04:58 PM
hardwood flloring installation bannasch Flooring 1 07-19-2008 12:44 AM
Hardwood floor installation on 2nd floor - underlayment necessary? digexpressions Flooring 2 11-30-2007 10:15 AM
engineered hardwood installation; Floating or Glue? El Buey Flooring 4 08-17-2007 02:53 PM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
