Wilsonart Padding - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2007, 08:34 PM   #1
wilsonart padding
I'm about to have some wilsonart red label laminate installed. I'm debating over the 2-in-1 padding versus the more expensive acoustic padding. In what situations would the acoustic padding be needed? Does it make difference walking over it ? I understand that non wilsonart padding would void the warranty. Laminate is being put in the first floor over the wood (plywood?) sub floor. thanks for any insight!
-shawn
shollada is offline   Reply With Quote
Old 07-06-2007, 09:37 PM   #2
Guest
Guest
Posts: n/a
I'd go with the better pad. We sell a couple different grades and you can definitely tell the difference. It's all about the sound. A better pad will absorb the sound of your footfalls and sound more like real wood, as opposed to the laminate it really is.
Old 07-11-2007, 10:15 PM   #3
Floorwizard's Avatar
I agree. Definately more comfy too.
Floorwizard is offline   Reply With Quote
Wilsonart post-form laminate countertops?? J187 Remodeling 7 05-04-2007 02:16 PM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 01:08 PM
Carpet Padding for Basement Kyle Flooring 2 10-14-2006 08:05 AM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 12:05 PM
