Old 09-20-2009, 06:04 PM   #1
Default Wilonart or Quick-step?
I've heard good things about quick-step. I had what I wanted picked out (Eligna Canyon Oak). I got the sample and it was perfect, not too dark, not to light, a touch of gold-is red to warm it up. Unfortunately, it seems that is discontinued. They have a similar color in the Elegance Line (but I really don't want the beveled edge—I want a uniform surface and no grooves to collect dirt).
I looked into Wilsonart. Local sellers really play up the heat and pressure manufacture of it as being way better than the pressure only. The WilsonArt is more expensive. However, I found several customer reviews re: water damage (reviewers claim just normal glass of water spill and dropped ice) and dulling surface.
Any experiences good and bad appreciated (especially from any pros who may have installed both products)
Thanks in advance,
Grant
gmhut is offline   Reply With Quote
Old 09-21-2009, 07:54 AM   #2
poppameth's Avatar
Wilsonart is an excellent product. Water can easily damage any laminate. I've never heard of Wilsonart being any worse in such situations. Quickstep is good too.
poppameth is offline   Reply With Quote
More On This Topic
I wanted to share with you some of the different types of bevels that they have available for you out there, when you're working on your glass projects. Now, a bevel is actually a piece of clear glass that has been smoothed and polished down on it's... Read More »
How to Determine Rock Shape
How to Determine Rock Shape by Expert Village
Hi I'm Jason with Expert Village.com. We're making the rock polish charm necklace. We've drilled holes, we've beveled the edges of the holes, and we've hit every surface with the cutting tool, and now for the last step of cutting we're going to do the... Read More »
Hi, I'm Jason with expertvillage.com. Today we're making the polished rock charm for a necklace. We've cut all the edges, cut all the surfaces down. We've drilled holes and beveled the edges. And after that we marked for all the deep scratches. Now I'm... Read More »
Hi, I'm Jason with ExpertVillage.com. Today we're making a rock polished charm, for a necklace. We've drilled both holes in each side of the rock and they've joined in the middle. I can still see there's a little bit in the middle that is not quite big... Read More »
So, after kind of all your beveling and your shading and kind of you get your 3D aspect together, I hope that you can see this kind of with the, kind of reflections, how it's kind of got a nice 3D surface to it. I mean it's kind of sort starting to look... Read More »
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 09:19 PM
Shaw vs. Quick Step melissamarie9 Flooring 12 07-02-2009 01:55 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-09-2009 01:02 AM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 06:11 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 04:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
