-   -   Will this work? (http://www.diychatroom.com/f5/will-work-166691/)
nstojic 12-17-2012 10:23 AM
Will this work?
Hi folks...
I have a concrete basement and wanted to tile. The concrete was old and fundamentally sound but the surface was a little beat up so I was going to level it out with self-levelling product from LevelQuik... That called for a latex primer of theirs to be put on before the compound; this product: http://www.custombuildingproducts.com/TDS/TDS-234.pdf
My issue arises when I realize that this concrete shouldn't be levelled because it slopes to a drain. So, I decide to use this resurfacing concrete: http://www.sakrete.com/uploads/downl...cer%205-12.pdf
My questions now becomes... Can I put the new compound over the latex primed concrete floor or should I strip the primer somehow and if so, with what? All I wanted was to 'clean' up the original concrete before I tile.. but I keep shooting myself in the foot...
Canarywood1 12-17-2012 12:32 PM
Originally Posted by nstojic (Post 1074508)
Hi folks...
A concrete floor needs to be free of any paint or sealers in order to use a topping,and the primer you used has a sealer in it.
nstojic 12-17-2012 12:44 PM
thanks for the info... if it's latex, can I remove it with a brush and some diluted paint thinner? or lacquer thinner? or graffiti remover?
Canarywood1 12-17-2012 02:13 PM
Latex is water based,so none of those will work,and it depends on what kind of sealer it is,hopefully not penetrating.
JazMan 12-17-2012 03:01 PM
The instructions on the Sakrete product you're thinking of using says;
"DO NOT USE A BONDING AGENT."
Removing the primer won't be easy, plus if I remember you're supposed to apply the patch within 24 hours of the primer, so it should not have been used already. oppps.
I think finding another product made by the same manufacturer, (Custom Building), is the best choice. Don't have an answer right now though.
Jaz
nstojic 12-17-2012 06:55 PM
Cwood, Jaz, thank you for replying. The manufacturer got back to me and says to just use "any solvent stripper". I'll let you know how it turns out.
JazMan 12-17-2012 07:09 PM
They did huh...... Well, generally we don't recommend that cuz the solvent gets soaked into the substrate and may become a bond-breaker. How are you gonna remove the film/residue from the concrete?
Jaz
nstojic 12-17-2012 07:30 PM
Jaz
I just can't win with this project :censored:
Doing some research, I was going to scrape off the residue and give the surface several turns of detergent/water
