Will This Work? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 02:13 PM   #1
Will this work?
I want to install hardwood floors, but my subfloor isn't up to snuff.
I was thinking about pouring some SLC, then glue and screw down some 1/2 inch ply on top of the leveled subfloor....
Will 1/2 inch ply be enough for the 3/4 prefinished hardwood planks to nail into? Can I go smaller? Do I even need to put another layer of plywood over the SLC?
adamavis is offline   Reply With Quote
Old 01-09-2012, 02:18 PM   #2
Ironlight's Avatar
What does "isn't up to snuff" mean? Could you be more specific about what the subfloor is, what it is supported by, what the perceived problems are, etc?
Ironlight is offline   Reply With Quote
Old 01-09-2012, 02:20 PM   #3
Sorry, The subfloor is 3/4 inch plywood. on one side of the house it's on 2x10's on the other it's supported by 2x8's.. I know... don't ask.
The floors are 40 years old and not level, and where the main beam of the house is there's an 1 1/2 inch drop because of the transition from 2x10 -> 2x8.
I'm just looking for a simple but respectable way to level out the floors.
Old 01-10-2012, 09:29 AM   #4
*crickets*
Old 01-10-2012, 10:09 AM   #5
Rewards Points: 13,458
Is there doors ways involved on the lower side?
If not you could add sleepers to raise the floor and have them come out level.
Tags
hardwood , slc , subfloor
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
