Will Piano Wheels Scratch A Laminate Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 06:11 AM   #1
sweaty
Rewards Points: 276
Will Piano Wheels Scratch a Laminate Floor?
I'm getting a laminated floor put in (Dupont) and have a 52-inch upright piano with little wheels. When I rearrange the living room furniture, will rolling the piano scratch the laminate?
sweaty is offline   Reply With Quote
Old 08-06-2011, 06:38 AM   #2
Rewards Points: 1,514
If the wheels are metal then yes they will scratch the floor. Some laminates have such a thin layer of color (possibly a photograph of wood on paper glued to the "floor board") that the surface will be irreparably damaged.
Even plastic wheels are not totally safe. Considerable force is exerted as the wheels re-orient themselves to the direction you are pushing the piano. Larger wheels are less likely to scratch compared with smaller wheels.
Old 08-06-2011, 08:42 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 122
Wheels or casters on furniture void the warranty on all laminate and/or sheet vinyl or vinyl planks. At least as far as I know.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-06-2011, 09:36 AM   #4
Experienced
Jackofall1's Avatar
They make felt pads specifically for your application, but I am not certain how this would effect your warranty.
Mark
Old 08-06-2011, 09:45 AM   #5
Wheels on Laminate
I'm pretty sure Rusty is correct. But to be absolutely certain, google Dupont, or call customer service (or read directions) and that should tell you also. Just to be sure...laminate is the rigid, plank type of flooring that is a floating floor. The design is made through a digitally computerized picture of wood (or ceramic if that is the style you have). Vinyl is just that...sheet, peel and stick squares or the vinyl planks. All are "floppy" so to speak. VCT tile (vinyl composition tile) is that good old fashioned tile everyone used in the 50's and 60's or a lot of people use in diners and what not. It cracks me up how many people confuse the two. Not to say that's what you did. Just saying....
ttr13r is offline   Reply With Quote
Old 08-06-2011, 10:25 AM   #6
I would just get a set of plastic furniture sliders.
You can get a set for less than $10 on Amazon.
GottaFixIt is offline   Reply With Quote
Old 08-06-2011, 08:56 PM   #7
sweaty
Rewards Points: 276
Installing Laminate Floor Parallel or Perpendicular to Joists
I'm going to have a laminate floor put in the main level of my house, which is 32' wide, 24' deep. As I enter the front door, I would like to see the planks longitudinally to make the little house seem bigger. But the joists run in that same direction. The longer part of the house runs sideways. Can I install it perpendicular in the rest of the house? Will a transition be needed between the sections?
Laminate on Concrete Floor OK & Heavy Piano??????????? sfagtjt Flooring 5 05-23-2011 09:51 AM
Laminate Floor and Island donb98 Flooring 1 10-21-2010 03:59 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 04:06 PM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
Cracked cement board floor under laminate dmozealous Flooring 1 05-07-2009 09:06 AM
