-   -   Will my sealed garage floor sweat? (http://www.diychatroom.com/f5/will-my-sealed-garage-floor-sweat-155150/)
Convict3 08-28-2012 08:14 PM
Im workingon the plans for a garage remodel. im planning to remove the doors and seal them up. Then install hvac,sprayfoam, electric tankless water heater, and sheetrock. Will the bare concrete slab floor sweat.
cleveman 08-28-2012 11:00 PM
Yes.
If you are running your a/c it won't matter and you won't even see it, right?
This spring, slabs were sweating like crazy as we went from cold temps to hot temps overnight.
Putting a lot of rock under it will help, as will a vapor barrier and/or insulation.
Keeping the doors closed will do the most good, as this will allow the building to heat up slowly.
It's just difficult to run a lot a of warm, wet air over an ice-cold surface and not expect it to pull the water out of the air.
