Will Mold Form Under Ceramic Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 12:29 PM   #1
Amateuralex's Avatar
Rewards Points: 270
will mold form under ceramic tile?
I keeping having people tell me that mold forms under ceramic tile. I have a 1979 bilevel with a dry, flat lower level with a concrete slab. I want to put ceramic tile on it. People keep saying that there will be mold problems. Are they correct?
Amateuralex is offline   Reply With Quote
Old 07-03-2012, 12:34 PM   #2
Rewards Points: 14,278
It's done all the time with no problums. In fact it's one of the best type floors to use in a basement.
Just do not lay a layer of tile board under it. Go right over the slab.
As long as there's not a flood and the grout is kept sealed every few years it should last longer then you and I.
Old 07-03-2012, 01:08 PM   #3
DIY staff
Rewards Points: 7,174
Tile is used in pools and fountains--
Use powdered thinset (cement based) and you are good,even if it get wet every now and then---Mike---
Old 07-03-2012, 01:36 PM   #4
Rewards Points: 270
OK I really appreciate the advice, thanks guys.
The Following User Says Thank You to Amateuralex For This Useful Post:
oh'mike (07-03-2012)
Old 07-06-2012, 08:38 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Mold needs an organic food source. There aren't any organics in ceramic tiles or cement or concrete floors.
Old 07-06-2012, 08:54 AM   #6
Renovations contractor
Bonzai's Avatar
I would always advise to use some form of crack prevention membrane when laying tile on slab ... As a very minimum use a modified thinset that has a high elasticity content. The crack prevention membrane (or uncoupling membrane) however will also act as a waterproofing layer so that any moisture penetrating the slab from below does not get to the thinset and loosen the bond. Whether this is really necessary also depends in part on where you are located ... Not a lot of ground moisture in the Arizona desert for example ;-)
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-06-2012, 09:02 AM   #7
Rewards Points: 270
That's very helpful advice. I am hoping to avoid using a crack prevention system, just to avoid the work. It's 650 square feet. There are a few very tiny cracks with no height difference and it's a 35 year old house. That makes me feel good about the cracks. I'll definitely use a modified thinset. I am planning on using 18X18 ceramic tiles, and will probably use this stuff (medium-bed thinset from reading other posts on this forum) from the Orange store: Custom Building Products 50 lb. Marble and Granite Fortified Premium Mortar.
The lower level is about 4 feet underground at the deepest. It has a walkout and low windows all around. It has a tile drain system and sump. It's flooded once in 30 years, but that's only because the previous owners abandoned the house, the utilities were shut off, and the sump pump lost power for 6 months. There's no evidence of water through the cinderblock walls or up through the slab.
How much of a pain is a crack prevention membrane to install on 650 square feet? In my situation, does it sound necessary?
Old 07-06-2012, 09:22 AM   #8
Bonzai's Avatar
If you go with Ditra (Schluter product) then it is pricey and takes some time for that amount of space however you get what you pay for in terms of uncoupling ability. However you could use something like Mapei HPG or RedGard which are both roll on liquid membranes ... They look kind of like a tub of thick yogurt (without any fruit lumps) and it's just like painting to apply it. We use these a lot for exactly this sort of application as well as waterproofing shower walls. Would take a couple of coats and when dry you have a rubber membrane on the slab. You may need about 4 tubs for that space ... Here in BC I pay around $60 for the Mapei HPG .. RedGard is closer to $80 for the same size. The big saving is in the labour as so quick to apply ... It dries in about 90 mins.
Whether you need it is hard to say ... It gives an extra level of protection. We guarantee our work so this is what we do to be comfortable giving that guarantee. Is it worth spending one more day and maybe $300 in relation to what you are already spending on the space ?
Old 07-06-2012, 09:29 AM   #9
Rewards Points: 270
Huh OK very interesting. Something like Redguard seems very plausible and relatively easy. I'll definitely consider this, thanks again for the advice.
Old 07-06-2012, 10:48 AM   #10
Bonzai's Avatar
It may well work without but as a contractor I need to give guarantees so I go the extra step. Minimum code does not require it but I am not a great believer in scraping by minimum code.
Old 07-06-2012, 10:49 AM   #11
Rewards Points: 270
Understood, makes sense.
Old 07-06-2012, 11:08 AM   #12
Bill Kearney
Rewards Points: 1,174
Man, a whole floor painted with Redguard... that's going to look like a slaughterhouse! I've used it behind bathroom tiles, interesting to hear someone using it for a whole floor.
wkearney99 is offline   Reply With Quote
Old 07-06-2012, 03:52 PM   #13
Bonzai's Avatar
The OP is going to tile on top of it ... Personally I would use the Mapei HPG as it is cheaper (here) and I find it goes further, plus it's a nice shade of baby blue as opposed to Barbie pink ;-)
Tile over existing ceramic tile jgb29 Tiling, ceramics, marble 4 03-26-2012 11:50 AM
New kitchen floor going in, deciding on a backboard/underlay for ceramic tile efciem Tiling, ceramics, marble 10 03-08-2012 08:26 PM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-23-2011 11:04 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 08:11 PM
