Will Laminate Flooring Work? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 03:44 PM   #1
Question
Will laminate flooring work?
I have a structure that is post and beam construction with no concrete foundation. The floor is between 2 ft. and 7 ft from the ground. I have a 12 x 20ft. room that I need to put flooring in. It has 2x6 car decking as subfloor. This is a vacation cabin so it sees temp swings from sitting at 30 degrees for a month, then heated up to 70 for the weekend.
I would like to install laminate flooring, but was not sure about expansion and contraction from temps and moisture?
Also when I go to install it I know it should acclimated, but do I acclimate it to 70 degrees?
Would an engineered nail down floor a better choice?
thanks for any input.
oregondiy is offline   Reply With Quote
Old 02-10-2009, 04:06 PM   #2
Floorwizard's Avatar
Wood and lam will react the same. The only Lam that was rated for cabins unheated here in Alaska was Armstrong.
At least that is the only REP from a major manufacturer that has told us it's good to go.
Let it acclimate at a warmer temp. Higher humidity.
Floorwizard is offline   Reply With Quote
Old 02-12-2009, 01:51 AM   #3
I guess what I would like to know is from the wide temperature, humidity swings will---
1. Will the laminate warp or cup?
2. Will the laminate expand and contract causing open seams between pieces?
3. Would an engineered wood floor be a better choice?
I would of course leave proper expansion gaps at edges, I am not worried about movement at edges.
I don't want to install a flooring that will not survive in these conditions and just have to be torn out later.
Thanks for anyones advice on this
Old 02-12-2009, 12:55 PM   #4
Yes
Yes
No
Best to go with a floating Vinyl. Glass backed.
You may be OK with lam, but it's a risk.
Floating Vinyl = no risk. And waterproof too!
Old 02-12-2009, 03:37 PM   #5
What is floating vinyl?
Like linoleum you might have in a normal house?
thanks
Old 02-12-2009, 05:56 PM   #6
The new Vinyl that is available now no longer has a fiber back to it.
It has a fiberglass back which makes it more resistant to ripping and also way easier for DIY.
It's also easy to replace down the road if need be.
I have no doubt that these will take over the Vinyl industry within 10 years or sooner.
It can be loose layed in most cases without adhesive.
This is your best option for the area based on what I hear.
www.carpetone.com
Use your zipcode to find a store near you and check out IVC Earthscapes.
Or any other store should also have some Mannington selections as well.
It's all over the place, so should be easy to find.
Old 02-13-2009, 12:57 AM   #7
I just really don't want vinyl, it is not the look I want to acheive
Old 02-13-2009, 12:30 PM   #8
OK then.
Just make sure if you get the material you want, it continues to give you the look you need.
If you want a wood look, then you would be suprised at what the new designs can give you in Vinyl.
Otherwise get wood or lam. Maybe it will gap or buckle...maybe it won't.
Old 02-16-2009, 10:29 PM   #9
Does anybody have any other experience with wood flooring in similar circumstance of vacation type homes that sit unheated for a few weeks then heated up. I would love if anybody had a first hand take on this.
thanks
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
Laminate Flooring Install Renovator Flooring 6 04-24-2006 11:42 PM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 05:09 AM
