Will I Need A Wet Saw If Dealing With 1" Mosaic - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 06:11 PM   #1
Rewards Points: 1,062
Question
will i need a wet saw if dealing with 1" mosaic
i wonder if i even need a wet saw if i'm dealing exclusively with 1" mosaic tiles. it looks like i should be able to make all adjustments with a pair of nippers.
Old 05-20-2011, 06:26 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
it easy to shatter 1" tiles with nippers. a good tile installer can make nice smooth cuts with nippers but the small 1" tiles can be really dense and hard to cut without breaking them. i like to trim them up with the edge of the wet saw blade as if it were a belt sander.
mustangmike3789 is offline   Reply With Quote
The Following User Says Thank You to mustangmike3789 For This Useful Post:
amakarevic (05-20-2011)
Old 05-20-2011, 06:28 PM   #3
Thumbs down
OK... so no way of getting out of buying a wet saw for me
Old 05-20-2011, 06:32 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
amakarevic,
How much tile are you dealing with?
What is the tile exactly?
With nippers you will probably ruin more tile than you care to.
You don't have to buy a wet saw necessarily either.
How about a little teensy tinesy itty bitty bit more information about what you are doing?
XXX
Old 05-20-2011, 06:35 PM   #5
i have to do TWO bathrooms in my house with 1" mosaic, ONE 15 sq ft boiler/waterheater alcove with 2" mosaic, ONE powder room with 1" mosaic, and ONE small kitchen with 1" mosaic.
the alcove and the powder room come first.
Old 05-20-2011, 06:38 PM   #6
Hey Bud -- can you please check out my other thread:
wet saw recommendation
thanks
Old 05-20-2011, 06:38 PM   #7
i would suggest one of the cheap table top saws in this case. it will do all of your straigt cuts, corner cuts and trimming. kind of an all in one tool.
Old 05-20-2011, 06:41 PM   #8
Question
thanks. what qualifies as a "cheap table top saw"? i submitted two MK proposals in the other thread, one for 4.5" blade one for $99 and another 7" one for $160.
Old 05-20-2011, 06:43 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay now we are getting somewhere!
If the tile doesn't fit within the wall confines that's a lot of tile to cut. That particular type of tile is probably going to be porcelain and it is very hard to cut and hard to deal with with just tile nippers.
For a lot less money you could buy a 4" right angle grinder and a diamond blade to fit it and dry-cut and score the tiles then use the nippers to make a clean break.
I will also warn you that some of those tiles are glued to their backing with a water-soluble adhesive. If using a wet saw you must make your cuts then quickly dry the tiles front and back before they begin coming loose and dripping from the backing. They aren't all made like that but many are. Why they do that is beyond me.
Dry-cutting may be your best bet.
Those cheap $80 wet saws probably aren't powerful enough to cut that much porcelain conveniently anyway.
XXX
Old 05-20-2011, 06:49 PM   #10
Question
you mean using a grinder with a diamond blade or a manual snap cutter like this one:
http://www.amazon.com/NATTCO-PC1818-..._bxgy_hi_img_b
Old 05-20-2011, 06:58 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A snap cutter won't work! Are you kidding me?
XXX
Old 05-20-2011, 07:04 PM   #12
OK. so what do you mean by dry cutting - a grinder?
Old 05-20-2011, 07:07 PM   #13
Question
Bud - in short, do you think if i buy this thing, it will solve all my problems:
http://www.amazon.com/MK-Diamond-157...ref=pd_cp_hi_1
Old 05-20-2011, 07:14 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope.
XXX
Old 05-20-2011, 07:23 PM   #15
OK but what will, considering the application described earlier? and why won't this cut it?
from all that's been said, sounds like the situation for me is hopeless for cutting tile and i have a hard time reconciling with the idea that, in this day and age, i can't find a inexpensive tool that will do it...
if i'm dry cutting with a 4.5" grinder and a diamond blade, will i need a vise to hold the tile while cutting? i can't imagine it's doable holding it in your one hand while using the grinder in the other.
scratching my head...
Do you have to seal marble and glass mosaic tile that is in the shower? debbieriddle Tiling, ceramics, marble 12 07-14-2012 11:32 PM
Need input please! (Mosaic on tile) tandj1997 Tiling, ceramics, marble 19 05-21-2011 11:53 PM
Sealing grout on a glass tile mosaic backsplash? smithers76 Tiling, ceramics, marble 1 05-08-2011 07:44 AM
Glass and metallic mosaic tile homefixgirl General DIY Discussions 9 12-23-2010 09:42 PM
2x2 mosaic w/paper mesh in shower gmbun Tiling, ceramics, marble 2 07-15-2009 05:13 PM
