Will This Floor Support Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 10:38 AM   #1
Will this floor support tile?
Hello all, forum noob here
So I am thinking of tiling my kitchen floor and I have been told I need to check my floor for deflection. I'm not sure how I would do that . I can tell you currently the floor joists are 2x10 spanning 12 feet unsupported. The subfloor looks to be 2 sheets 3/4" plywood. Is that enough to support tile?
*edit* forgot to add that the joists are 16" on center
K. Olsen is offline   Reply With Quote
Old 08-28-2012, 11:13 AM   #2
Rewards Points: 1,574
Not sure what others on this forum think of it but you could try:
http://www.johnbridge.com/vbulletin/deflecto.pl
You'll need to find the species of the lumber your joists are made from. Usually it is ink-stamped on the side of the joist.
bob22 is offline   Reply With Quote
Old 08-28-2012, 03:28 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
Hi Olsen,
Your joist set up is stiff enough for ceramic tiles as long as they're in good shape. The two layers of plywood also make that deflection plenty good for ceramic tiles.
All you need is to chose a tile backer or membrane and then tile away. Please come back for more detailed info as needed.
Bob,
Although I know and like John and I am on the site too, It is rather low class to send DIY Chatroom customers to other sites. Why didn't you just answer Olsen's question?
Jaz
Old 08-28-2012, 04:23 PM   #4
thanks for the replies. I did check the joists and they've been in there since 86 I think the ink has faded . They do look a lot like yellow pine though and they are in good shape.
Old 08-28-2012, 07:20 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
OK, sounds good. SYP (Southern Yellow Pine), is very common and one of the stiffest species of wood for joists. They normally use grade #2, but many other grades are available and is why I ask for the grade, but rarely can the people read it on the lumber.
What's next?
Jaz
Old 08-29-2012, 11:23 AM   #6
Originally Posted by JazMan View Post
What's next?
Shopping for tile
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
