Wide Plank Screw And Plug - Flooring - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 10:03 AM   #1
Rewards Points: 12
Wide plank screw and plug
Hello All
I am going to be putting in a wide plank floor in our home. We would like to do the screw and plug method.
We will be using contrasting woods, light floor with dark plugs.
I can find a plug cutting bits all over the internet but I can not find a bit that will drill a pilot hole as well as make the recess for the plug.
Is there a kit with all the bits I need or do you know of a bit that will do what I need, or will I need 2 bits one for the screw pilot hole and one for the plug hole.
Thank You
Al
agmccall is offline   Reply With Quote
Old 06-05-2010, 06:03 PM   #2
jlhaslip's Avatar
Rewards Points: 1,502
pick your size... the depth of the countersink is adjustable.
http://www.leevalley.com/en/wood/pag...at=1,180,42240
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
adding a plug from a switch that has red,white,black, and bare Limit54 Electrical 18 03-09-2010 07:14 AM
plug problems in the house. Ivancar1 Electrical 10 07-05-2009 08:42 PM
repairing red wooding plank mnulty Building & Construction 6 07-16-2008 10:51 PM
Screw and plug 5/4" PTP decking Klaus Building & Construction 3 06-10-2008 07:01 AM
convert plug in light with screw in hornet1946 Electrical 5 01-31-2008 06:00 PM
