Old 10-25-2009, 04:55 AM   #1
dtc
Question Why is my carpet self-destructing?
In July I had carpeting installed. When I run my Dyson vacuum over it, it sometimes catches a yard and tears it out. This is destroying the carpet, and could destroy my Dyson!
Here's two (out of 3) spots:
It looks like this is happening at the seams. Unfortunately, I had no input on the choice of carpet, the store, nor the installation - but I paid. (Family thing, it's complicated.)
Is this because the carpet was installed incorrectly? What should have happened?
Is this something I should fix myself, or should I go complain to the carpet store?
Also, I notice in some spots of the carpet, it feels like I'm walking on metal parts - possibly popped nails? hidden bolts? screws? Is it their responsibility to straighten this kind of stuff out before they take install the carpet after removing the old one? Or in other words - is this something I can legit complain about as well?
What a mess.
Thanks!
dtc is offline   Reply With Quote
Old 10-25-2009, 09:17 AM   #2
ccarlisle's Avatar
A very common problem with industrial carpets called 'tufted' that have a polypropylene backing and various length of filament yarns. This type of carpeting accounts for ~80% of the carpet out there...cheap to make, look OK - but suffer from the same problem: catching a filament in a vacuum cleaner beater bar and unravelling the whole thing. Typically happens at seams...
Seams should all be sealed with latex glue as the filaments on a seam can't just be left "hanging". Residential and Industrial carpetting installation standards require sealing to be done - by obviously your guy didn't...but maybe he was a cheap "fly-by-nighter" - depends what you paid for and from whom...
That's an installation issue and is fixable. Who pays for it depends...
ccarlisle is offline   Reply With Quote
Old 10-25-2009, 12:42 PM   #3
37 year installer
rusty baker's Avatar
Look at your warranty. According to most carpet mills, a Dyson is the worst vacuum to use on carpet. It voids most carpet warranties. It is poorly engineered. The Dyson beats the crap out of carpet and not in a good way. Also, no beater bar vacuum is supposed to be used on loop carpet. If you weren't warned by your retailer,you shoud have been. Even sealing the seams won't help with a Dyson.
If'n you can't fix it with duct tape, it can't be fixed!
More On This Topic
Carpet Installation Tips
Carpet Installation Tips by Expert Village
Learn all about carpet installation with expert tips on how to pick carpets and rugs in this free home decor video clip. Read More »
How to Spray Carpet Spots
How to Spray Carpet Spots by Expert Village
Got Carpet Stains? Learn the best way to clean your carpet with machines in this free video clip about using sprays to clean carpet. Read More »
Got Carpet Stains? Learn the best way to clean your carpet with machines in this free video clip about how remove spots from carpet. Read More »
Got Carpet Stains? Learn the best way to clean your carpet with machines in this free video clip about tips for removing carpet stains and spots. Read More »
Carpet Cleaning Checklist
Carpet Cleaning Checklist by Expert Village
Got Carpet Stains? Learn the best way to clean your carpet with machines in this free video clip about using spot treatments on carpet. Read More »
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 03:23 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 09:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 6 09-30-2007 10:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
