Why Cut Off Tongue Of First Row Of Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 10:01 AM   #1
Why cut off tongue of first row of laminate?
Hello, I am a new to this forum and am nearing laying the first board on my first laminate flooring project. I am installing pergo over concrete with vapor barrier. I've pried up baseboards, patched, sanded, cleaned and painted walls, pulled up carpet, pad, tack strips and thresholds to vinyl. I'm a middle-aged, fat, lazy & anal woman reading all the articles & manufacturer instructions plotting out my steps for the actual laying of the floor. I am studying the operating manual on a ryobi 10 inch compound miter saw I have on loan for the project. I'm going to be putting the baseboard back on and then quarter-round. why does the tongue need to be cut off the first row of laminate? I worry about losing my guaranteed straight edge I'm starting with. Thanks for any advice!
sammie10 is offline   Reply With Quote
Old 02-21-2010, 10:22 AM   #2
jlhaslip's Avatar
Rewards Points: 2,864
never done it myself.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-21-2010, 12:38 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
depending on what is used for a base moulding, that tongue could allow too much of a space between the wall and the first floor board. You need to leave a gap around the floor to begin with so when you add that gap to the tongue, the distance to the actual floor surface can get wider than many base moulding treatments.
you have to realize, if you are required to allow a 1/2" gap, that is going to be from the closest point to the wall from any point on the board. If you leave the tongue on, that would mean the measurement would be from the tip of the tongue to the wall.
other than that, there is no need to do it that I know of.
removing the tongue would be much better performed by using a table saw where you will maintain your factory straight edge much easier.
Old 02-21-2010, 12:56 PM   #4
Thanks...
That makes sense. Since I'm going to use quarter round & base molding & have the floor colored sealant for perimeter, I think I'm going to leave the tongue on.
I also found out the mitre saw won't work, only good for up to 6inch widths. I'll have to use my jigsaw for now and figure out how to get a table saw or something else by the time I need to do length cuts.
Thanks!!
Old 02-21-2010, 01:22 PM   #5
Jigsaws and miter saws are great tools for laminate flooring when the cut edge is hidden by moulding. Laminate flooring is hard on your blades so unless you need perfection I would not use my best blades. Typical 10" mitersaw has a horizontal cross cut capacity of 6" and you can simply flip the board for wider laminates.
aggreX is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 01:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Can't decide: Laminate or Engineered? rogersmj Flooring 7 08-30-2009 08:10 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
