whole bathroom shower basin?
What you are proposing, basically, is a "low-threshold handicap accessible shower", and googling that will find you a number of manufacturers of ADA compliant shower bases and complete shower enclosure kits.
There is no reason of course where you can custom build a tile shower of the same general design, but to do it right is going to be an expensive project, and if it's done wrong and your room-sized "shower base" leaks, you may find that you are tearing the whole thing out to fix it!
So you might want to consider the possibility of using a pre-manufactured base, and devoting any excess bathroom square footage to storage.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
