White Oak Or Red Oak? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 04:50 AM   #16
DIY staff
Rewards Points: 7,174
Most floor finishers use a buffer with a fine screen to even out the sanding---then again to buff out boogers between coats---
Old 10-18-2012, 05:12 AM   #17
Rewards Points: 150
I've heard of the buffing between coats of poly, but only using a hand screen. Everyone I talked to recommended not putting a heavy buffer on a fresh poly'd floor because of the fear of track marks from the wheels.
Squished is offline   Reply With Quote
Old 10-18-2012, 05:25 AM   #18
DIY staff
The wheels on a floor buffer are only used for transport--they do not touch the floor when the buffer is in use---
I'm not a finisher---but I have had plenty of wood floors finished in the course of my work---all of them buffed after sanding---then again to remove bubbles and dust before the last coat--
Old 10-18-2012, 05:27 AM   #19
Rewards Points: 150
Gotcha, I know the exact machine you're talking about. That's definitely an option. The floor isn't that big, a hand screener on a pole is probably what I'll use to just to level out the boogers between coats.
Old 10-18-2012, 05:39 AM   #20
DIY staff
That will work----no need to spend 3 hours travel to rent a tool for a 1 hour job---
basic white paint mcl6302 Painting 6 10-11-2010 05:58 PM
turning white to antique white rustyedge Painting 6 10-01-2010 01:08 PM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 09:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
ceiling not white cart Painting 7 06-22-2008 08:32 AM
