White Oak Or Red Oak? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 06:45 PM   #1
Rewards Points: 150
White Oak or Red Oak?
Probably comes up a million times, but I figured this needed a new thread. Had 4 hardwood floors guys come out to look at my 90 year old living room floor that needs to be refinished, then look at the kitchen floor that needs to be installed next to it. The two rooms touch so the wood in each needs to be the same.
Here's my problem, 2 hardwood guys said my existing floor is red oak, 2 hardwood guys say the existing floor is white oak. Obviously, if I buy the wrong wood, the two floors won't match. I took a picture of the end grain and top grain, can anyone here help me distinguish? I tried to google it, I'm leaning towards white oak from my research based on the top look, but the end grain is screaming red oak. I'm stumped.
Thanks in advance. I'm supplying the wood so I don't want to buy wrong.
Squished is offline   Reply With Quote
Old 10-08-2012, 07:07 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Sure looks like White Oak to me. Here is a wood ID site you can check your wood against.
http://www.hobbithouseinc.com/personal/woodpics/
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-08-2012, 07:14 PM   #3
Rewards Points: 150
Originally Posted by Squished View Post
This was from the white pictures that you linked:
http://www.hobbithouseinc.com/person...0q60%20plh.jpg
Old 10-08-2012, 07:21 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Red Oak has small pin holes in the end grain, White Oak has very few if any small holes in the end grain. White Oak has brownish color to it where Red Oak has a pinkish slight redish color, also White Oak is heavier.
Jim
Old 10-08-2012, 09:09 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Looks like white oak to me, too.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-08-2012, 09:30 PM   #6
Rewards Points: 13,446
http://www.bing.com/images/search?q=...F9FE83&first=1
http://www.bing.com/images/search?q=...+oak+end+grain
If you have a sample of the flooring you have now one test is to try blowing smoke through the end of the piece, not a smoker then just put one end in some water and blow on the other. If air passes through it, it's red oak.
One of the many reasons wooden buckets, barrels anything made to hold liquid should not be red oak.
rusty baker (10-08-2012)
Old 10-08-2012, 10:00 PM   #7
Rewards Points: 150
I'll put the piece i have in water tomorrow and test it. Thanks.
Old 10-08-2012, 10:03 PM   #8
Just try to blow on it as if it was a straw. Should see bubbles.
Old 10-08-2012, 10:25 PM   #9
Rewards Points: 558
you can also go to this site and read # 3
http://www.wood-database.com/wood-ar...rom-white-oak/
epson is offline   Reply With Quote
Old 10-09-2012, 04:38 AM   #10
Rewards Points: 150
No bubbles. Looks like it's white oak.
The Following User Says Thank You to Squished For This Useful Post:
BigJim (10-09-2012)
Old 10-10-2012, 04:17 AM   #11
Rewards Points: 150
Unbelievable, even after the bubble test had one more 40+ year general contractor swear it's red oak. I can't seem to find the sodium nitrite to do the scientific test on it either.
Old 10-17-2012, 04:36 PM   #12
Talking
Ok positive ID available:
http://www.fpl.fs.fed.us/research/ce...dfactsheet.php
additionally go to this website and it will tell you how to send in a sample to the US Forestry Service and they will id it for you.
Jim Decker NWFA Certified Hardwood Inspector
Typically Red Oak looks reddish White Oak looks kind of grayish
Jim Decker is offline   Reply With Quote
Old 10-17-2012, 08:30 PM   #13
Rewards Points: 150
I actually had it chemically tested a flooring supply place. Turns out it was white oak! Good call everyone.
oh'mike (10-17-2012)
Old 10-17-2012, 08:39 PM   #14
DIY staff
Rewards Points: 7,174
White oak is harder than red--and is much more resistant to water damage---a better wood for floors that take a beating---
Old 10-17-2012, 08:43 PM   #15
Rewards Points: 150
you have that right! I've been sanding down the edges of my existing floor in preparation for sanding it and I'm chewing through sandpaper like crazy. Can't wait to rent the machine from Home Depot on Sunday and do the middle of the floor. If the edges are any indication of how the middle will look, it's going to come out great. I received quotes of $1500 and up to refinish this floor and finish the new floor im putting down (600 sq feet), so far I'm in it for $125 in gloss Poly, $50 in sandpaper and poly applicators, and $75 when I rent the machine. $250 versus $1500, nice savings!
oh'mike (10-18-2012)
basic white paint mcl6302 Painting 6 10-11-2010 04:58 PM
turning white to antique white rustyedge Painting 6 10-01-2010 12:08 PM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 08:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
ceiling not white cart Painting 7 06-22-2008 07:32 AM
