White Oak or Red Oak?
Probably comes up a million times, but I figured this needed a new thread. Had 4 hardwood floors guys come out to look at my 90 year old living room floor that needs to be refinished, then look at the kitchen floor that needs to be installed next to it. The two rooms touch so the wood in each needs to be the same.
Here's my problem, 2 hardwood guys said my existing floor is red oak, 2 hardwood guys say the existing floor is white oak. Obviously, if I buy the wrong wood, the two floors won't match. I took a picture of the end grain and top grain, can anyone here help me distinguish? I tried to google it, I'm leaning towards white oak from my research based on the top look, but the end grain is screaming red oak. I'm stumped. http://i222.photobucket.com/albums/d...008_193919.jpg http://i222.photobucket.com/albums/d...008_193931.jpg http://i222.photobucket.com/albums/d...008_193939.jpg http://i222.photobucket.com/albums/d...008_193950.jpg http://i222.photobucket.com/albums/d...008_194006.jpg Thanks in advance. I'm supplying the wood so I don't want to buy wrong. |
Sure looks like White Oak to me. Here is a wood ID site you can check your wood against.
http://www.hobbithouseinc.com/personal/woodpics/ |
http://www.hobbithouseinc.com/person...0q60%20plh.jpg |
Red Oak has small pin holes in the end grain, White Oak has very few if any small holes in the end grain. White Oak has brownish color to it where Red Oak has a pinkish slight redish color, also White Oak is heavier.
Looks like white oak to me, too.
http://www.bing.com/images/search?q=...F9FE83&first=1
http://www.bing.com/images/search?q=...+oak+end+grain If you have a sample of the flooring you have now one test is to try blowing smoke through the end of the piece, not a smoker then just put one end in some water and blow on the other. If air passes through it, it's red oak. One of the many reasons wooden buckets, barrels anything made to hold liquid should not be red oak. |
I'll put the piece i have in water tomorrow and test it. Thanks.
Just try to blow on it as if it was a straw. Should see bubbles.
you can also go to this site and read # 3
http://www.wood-database.com/wood-ar...rom-white-oak/ |
No bubbles. Looks like it's white oak.
Unbelievable, even after the bubble test had one more 40+ year general contractor swear it's red oak. I can't seem to find the sodium nitrite to do the scientific test on it either.
Ok positive ID available: http://www.fpl.fs.fed.us/research/ce...dfactsheet.php additionally go to this website and it will tell you how to send in a sample to the US Forestry Service and they will id it for you. Jim Decker NWFA Certified Hardwood Inspector Typically Red Oak looks reddish White Oak looks kind of grayish |
I actually had it chemically tested a flooring supply place. Turns out it was white oak! Good call everyone.
White oak is harder than red--and is much more resistant to water damage---a better wood for floors that take a beating---
| All times are GMT -4. The time now is 04:51 AM. |
