White Hazy Oily Film on Newly Refinished Hardwood Floors
Who is "the guy?" I think that if you paid "the guy" that "the guy" should come back and fix it. Why are trying to fix something that you are not liable to fix? It sounds like an oil coating was put on too thick or not allowed to cure, or both. If the humidity was high, this would make the problem worse. Sounds like the whole thing might need to be redone because there is no fix to this type of problem. Without knowing the products that "the guy" used and how they were applied, this is only a guess.
If this was a contractor, you need to have them fix it and not pull your hair out trying to fix someone's mistake that you paid for.
Josh Jaros Remodeling in The Woodlands, Texas To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
