I installed a new tile floor in my kitchen. The grout I purchased was supposed to be light grey but looks almost white. There are also areas in the grout that are darker(more like the correct color). I can't tell if the grout just turned out lighter and I have dark spots or if the grout IS darker and there is a white haze actually ON the grout. How can I tell? I know that using too much water when mixing or when cleaning can cause inconsistencies, but not sure where to go from here. I would like to avoid staining the grout if possible.
I only use either the Mapei grouts or the Prism brand by Custom. They both have great color consistency and low shrinkage ... They both set up very fast though.
Your options are basically to stain a darker shade or scrape out and start over.
Try using an 'enhancing' sealer in a discrete spot--the enhancing sealers leave the grout darker--like they look when wet---it's a way to save a blotchy grout job.
Over washing the wet grout is often the cause---to much water in the sponge---
Was it all one batch of grout or is the area large enough that you had to mix a few lots of grout? Unless you are consistent and depending on which grout you used (different makes of grout have varying colour consistency) then the colour may vary depending on the water/mix ratio. Also did you post this thread right after grouting or has it actually fully cured yet? Have you sealed the grout?
Bonzai...it was multiple batches from the same bag...I was mixing a little at a time since this was my first time..the area was about 200 sf. The problem is pretty consistent throughout the entire floor. It has been 6 days since I grouted and I have not sealed it. I tried cleaning off with water and a toothbrush but it doesn't seem to help...when it's wet it even's out to the light grey but when it dries it's white again. I haven't tried anything else for fear of making things worse.
Cleveman...would the acid harm the tile? It's porcelain. My main concern is making the grout color consistent at this point. The lighter color would be ok if not for the darker spots because it causes the grout to look dirty.
Yeah, you think? to recommend Muriatic acid indoor is beyond irresponsible. Don't do it. Instead try white vinegar and see if it'll fix this for you. Try a mild solution like 1:10 or so, but even 50:50 or straight can be used. If that doesn't work you can use Sulfamic Acid crystals per directions.
I agree with the sulfamic acid. I bought some of this to clean tiles in my own house and it worked very well. Just follow the directions, it's strong stuff.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
