White Grout Diacoloring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-08-2014, 10:17 PM   #1
Rewards Points: 398
Just over a year ago I re-grouted our bathroom floor and around the tub.
It seems like the traffic areas have since discolored to tan or off-white. If you look at the first picture you can see the difference between the tub tile and the floor tile color - both were done at the same time.
With the second picture I removed the floor mat to show how the grout under it is still white in comparison to the rest of the floor.
Any thoughts on how to bring it back white?
White grout diacoloring-image-1643533819.jpg   White grout diacoloring-image-809907097.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 02-09-2014, 12:17 AM   #2
Rewards Points: 6,652
Hair spray products is the main culprit, why you see that. Get some Sudsy Ammonia and a scrub brush. Put about a cup or two in a bucket of hot water, then start scrubbing the floor.
Extract the water off the tile with some old towels, then wipe down with plain Hot Water with nothing in it, and it should look fine after you are done.
Old 02-09-2014, 08:00 AM   #3
Rewards Points: 13,752
Did you seal the grout?
Old 02-09-2014, 01:15 PM   #4
Rewards Points: 398
I did seal it. I will try using ammonia and see what happens.
White Haze on Grout?? Jlail9905 Flooring 9 06-24-2012 01:08 AM
How can I remove grout sealer white taint? sukhenkoi Kitchen & Bath Remodeling 2 07-29-2011 10:52 AM
Using white thinset with dark grey grout. sukhenkoi Tiling, ceramics, marble 5 04-20-2010 06:54 AM
Will white grout stay white if sealed? fix it Flooring 3 12-01-2009 07:44 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
