Old 10-05-2007, 10:00 PM   #1
Where to start?
Hello all,
I am installing Shaw laminate this weekend. I have everything prepped in the bedroom where I am beginning but I am running into kind of a snag. Everything I've read says to start left to right, which I am, but it doesn't say anything about how to start if there is an existing door into the room that you are going! I am adding pictures for reference. Any answers or ideas would be great!
door frame
inside looking out
And lastly--there is a large gap going from the bedroom into the bathroom where tile is laid. The threshold seems to be much higher than what the new floor is going to be. Any ideas?
loomis1228 is offline   Reply With Quote
Old 10-05-2007, 10:56 PM   #2
Floorwizard's Avatar
Where to start?
You will need to undercut the door jambs to slide the lam underneath them.
I hope that helps a bit
Floorwizard is offline   Reply With Quote
Old 10-09-2007, 12:02 PM   #3
Zoomingo
Where to start?
Looks good how you have it...you will just need to strip between your starting row and then a transition piece from the laminate to the tile.
Hope this helps.
Jason
zoomingo.com
Zoomingo is offline   Reply With Quote
Old 10-09-2007, 08:34 PM   #4
Where to start?
Originally Posted by loomis1228 View Post
Hello all,
door frame
inside looking out
I'm late getting here. How did it go?
flooring dude is offline   Reply With Quote
Old 10-11-2007, 11:52 PM   #5
Where to start?
Yea, Don't forget to post new pics...
Old 10-24-2007, 02:28 PM   #6
Where to start?
It went terribly. I had to have 3 different people come in to help. 1 to show me what I was doing wrong; 2 to finish it for me.
Love the floor but it was harder than what everything that I read and talked to people about.
Old 10-24-2007, 03:18 PM   #7
poppameth
Guest
Posts: n/a
Where to start?
Shaw is a little different than some other laminates. Their newer locking systems have to be installed correctly, that is you have to lift and drop them into place. A lot of other systems allow the laminate to be placed flat and tapped into place instead of clicking down like you are suppose to. It's easier to cheat that way but it damages the laminate itself.
Help Diagnose Rheem 80+ - wont start RFM HVAC 2 04-10-2007 08:17 PM
Comfortmaker GNL won't start Hollandpiper HVAC 2 10-10-2006 03:37 PM
Girl wants to start wood work, tools? putri Carpentry 8 08-14-2006 07:58 PM
start furnace without igniter??? repairrick HVAC 1 02-24-2006 10:45 PM
