Where To Get 1/4" Thick Hardwood Floors? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-25-2006, 03:38 PM   #1
where to get 1/4" thick hardwood floors?
I have been shopping for engineered floors to replace carpet on 1st and 2nd floors. I know I will go with engineered (probably something like brazilian cherry floating) on the first floor.
the 2nd floor however, has solid hardwood in some rooms. the house was build almost 30 years ago, and the hardwood is 1/4" thick. I searched all over the internet and I cannot find anything like this. I want to get solid hardwood with the same thickness so the hallway will be level with the bedrooms.... this not only looks good, but also is safer. I don't want the hallway to be higher than the top of the stairs, which would cause people to slip and roll down the stairs.. not a pretty scene.
any ideas?
dozu is offline   Reply With Quote
Old 09-25-2006, 03:45 PM   #2
DIY'er
Rewards Points: 150
Are you sure it is 1/4 inch and NOT 5/16?
5/16 is readily available.
Doug Russell
"What if the hokey pokey really IS what its all about."
dougrus is offline   Reply With Quote
Old 04-29-2011, 10:36 PM   #3
maybe it was 5/16 and was refinished once
Old 04-30-2011, 05:17 AM   #4
woodman58's Avatar
Bruce Hardwoods makes a 5/16" solid floor. It is Natual Choice. Or Natual Reflections at the box stores.
woodman58 is offline   Reply With Quote
Hardwood Floors Josh89 Flooring 10 01-04-2010 08:22 AM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
Installing hardwood floors helpless handyman Carpentry 10 04-09-2007 09:23 PM
Hardwood floors helpless handyman Flooring 3 01-09-2007 08:30 PM
polyurethane coat for hardwood floors. christy123 Flooring 2 12-10-2006 10:20 PM
