Where Do You Place The Tack Strip At The Laminate/carpet Transition? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-12-2010, 07:40 PM   #1
Where do you place the tack strip at the laminate/carpet transition?
Hi, I just have a quick question. I've removed the carpet in the hallway so I can place laminate there. Some of the rooms off of the hallway still have carpet so I'm having to install a tack strip at each doorway. Where exactly should the tack strip be placed to ensure that the transition fits well. Just under the carpet or back under the carpet a bit?
Thanks!
Player is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Removing tack strip nails beerdog Flooring 3 04-04-2010 02:23 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 01:12 AM
transition strip to lay cut rug on a curve ? ? ? stadry Flooring 3 07-30-2009 01:46 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
