Where Do I Start... - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 03:01 PM   #1
where do i start...
Just moved into this damn ole house :-) trying to figure out where we start to get this floor fixed. This is a second floor bedroom. There is a layer of this green vinyl flooring. It just peels away. Under that are flat wood boards that also just lift up. In order to lay hardwoods or carpeting what needs to come up?? Should I just remove everything and start from scratch? Or can I create a floating floor over this horrid mess??
Amanda2013 is offline   Reply With Quote
Old 03-10-2013, 04:49 PM   #2
Rewards Points: 14,026
How it's going to come out and "feel will depend a lot on those floor joist.
Under sized and over spaned floor joist in an old houes are almost a givin.
Now's the time to checking for sagging and floor bounce.
Joist may need to be sister to get rid of the problums before any subflooring goes in.
Old 03-10-2013, 05:08 PM   #3
Rewards Points: 44
I'm not an expert. Just throwing it out there since it's an old house. Those floor tiles may contain asbestos.
djlandkpl is offline   Reply With Quote
Old 03-10-2013, 05:52 PM   #4
Roofmaster
Rewards Points: 2,210
Regardless of what kind of finish floor you want to end up with you need to have a proper structural subfloor. It is really hard for us to tell what you have there. Is this just one small area, or is the whole floor like this? The reason I ask is that the subfloor on many older houses consisted of 1 x 6 T&G fir run diagonally across the floor joists. Yours arent run like this. If this were mine, I would remove all base trim, cut out the subfloor and throw it in the dumpster, run any additional electric that I wanted to install, block the edges between joists where the new floor is going, and install 3/4 inch T&G plugged and sanded plywood subfloor perpendicular to the joists. You should check the floor to see how bouncy it is and sister joists where needed, as recommended by Joe too. The new subfloor should be set in liquid nails and nailed with 8d ring shank nails to the joists.
new pergo - where to start laying first course snowninja Flooring 4 09-25-2010 04:47 PM
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 01:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
