Where To Center The T-molding Under Doorway - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2006, 10:37 PM   #1
Where to center the t-molding under doorway
Hi, I am installing laminate flooring in the hallway and 3 bedrooms.
My question is where should I leave the 1 inch gap required for t-molding under the doorway. Should it be under the doorstop or directly under the door? or does it matter. It would be easier for me to install in under the door, then when I install the flooring in each bedroom I just have to follow the perimeter of the wall without extending into the hallway.
Appreciate any advice.
bipkis99 is offline   Reply With Quote
Old 07-14-2006, 10:46 PM   #2
renovations
It's 'supposed' to be under the door so that with the door closed the transition is invisible. But it isn't critical.
Bonus is offline   Reply With Quote
Old 07-16-2006, 06:03 PM   #3
pro flooring installer
Send a message via AIM to floorman Send a message via Yahoo to floorman
although not critical, it is from an asthetic point of view the way to break that and put the transition under the doorway like was stated in the previous post
floorman is offline   Reply With Quote
Old 07-17-2006, 10:10 PM   #4
Floorwizard's Avatar
yup. i agree
Floorwizard is offline   Reply With Quote
Painting floor molding with existing carpeting jscott1206 Painting 6 11-08-2008 03:43 PM
Baseboard molding tiled in... Donald Lynskey General DIY Discussions 1 07-07-2007 06:47 PM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 07:13 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 08:52 PM
Need to Cement Up old Basement Doorway BigArnold Building & Construction 1 12-29-2006 03:52 PM
