When To Use A Transition Strip - Flooring - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 09:16 AM   #1
When to use a transition strip
What is the max width of a room can be before you need to use a transition strip. I have a 20 foot wide room that i spit with pocket doors. I would like to have one continous look when i put down a laminate floor . Is it ok not to use the strip at the pocket door entrance
stevenson66 is offline   Reply With Quote
Old 11-18-2010, 06:04 PM   #2
Rewards Points: 266
Pictures would help. I would think the only time you really need a transition strip is when you have two different flooring materials or two different levels coming together. If you are saying that a continuous floor is not possible in this room for some reason then it seems to me that the pocket doors would be the place to put the transition but like I said, pictures would help.
Jim F is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Where do you place the tack strip at the laminate/carpet transition? Player Flooring 0 07-12-2010 07:40 PM
ceramic tile transition to laminate Kman92592 General DIY Discussions 1 07-01-2010 10:55 PM
transition strip to lay cut rug on a curve ? ? ? stadry Flooring 3 07-30-2009 01:46 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
