Whats The Best Way To Fill A Gap In Hardwood Floor Thats About 2 Dimes Wide? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-22-2015, 12:05 AM   #1
Rewards Points: 39
Whats the best way to fill a gap in hardwood floor thats about 2 dimes wide?
Whats the best way to fill a gap in hardwood floor that's about 2 dimes wide?
Any product recommendations?
bugmenot is offline   Reply With Quote
Old 11-22-2015, 01:10 AM   #2
Rewards Points: 6
Where in the flooring is the gap?
Perimeter or out on the field?
How long is the gap?
Have any pictures?
asevereid is online now   Reply With Quote
The Following User Says Thank You to asevereid For This Useful Post:
bugmenot (11-22-2015)
Old 11-22-2015, 01:21 AM   #3
Rewards Points: 39
Have any pictures?
The gap is around 10 inches long and its at the perimeter right next to the base board.
Old 11-22-2015, 02:19 AM   #4
Rewards Points: 6
OK, that's not bad at all.
You MAY be able to wedge that gap closed off you remove the base board and drive two opposing wedges in the gap between the flooring and the wall.
If the gap closes up you can then drive a few trim screws into the plank at the perimeter. Those holes can just be filled a basic wood filler and colored with a stain pen, or filled with a color matched putty stick.
At least, that's what I would do...
Or do you mean that it's right beside/under the baseboards?
Old 11-22-2015, 06:08 PM   #5
Rewards Points: 39
See attached picture of crack per your suggestion
Whats the best way to fill a gap in hardwood floor thats about 2 dimes wide?-hardwoodcrack.jpg
The Following User Says Thank You to bugmenot For This Useful Post:
asevereid (11-22-2015)
Old 11-22-2015, 06:12 PM   #6
Rewards Points: 6
Alright, thanks.
Yep, you may be able to wedge that back tightly.
Good luck.
ron45 (11-23-2015)
Old 11-22-2015, 07:31 PM   #7
Rewards Points: 2,180
Color matched caulk. Crack will likely change size over the course of heating/cooling season. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
Old 11-22-2015, 08:48 PM   #8
Rewards Points: 39
Would wood putty work? Does color matched caulk have any additional benefits over wood putty or wood filler? I don't want to refinish the wood if I can get away with it.
Old 11-22-2015, 08:57 PM   #9
Rewards Points: 5,326
Maybe we could use excrement. Human, maybe a beloved pet. Maybe alter the diet to get the correct color.
Ron
B. Franklin 1759
Old 11-23-2015, 08:31 PM   #10
Rewards Points: 39
You are such a bright individual. What would we do without input from intellectual luminaries like you.
Tags
hardwood floors
hardwood to ceramic no transition strip alaus24 Flooring 2 11-30-2010 10:53 AM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 09:14 PM
How to fill gaps in hardwood floors ponch37300 Flooring 2 04-16-2009 05:30 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
How do I fill wide gap between tub and tile...caulk? Derby General DIY Discussions 4 03-22-2005 12:19 AM
