What's Best To Cover Linoleum Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 09:24 AM   #1
What's best to cover linoleum floor?
My kitchen floor is old linoleum which is in great shape and glued down pretty good. I wanted to cover it up with something different and wanted to know if I can go right over the existing floor. I don't have any experience with tiling so I was trying to stay away from that. I like the new interlocking tile that snaps together and just needs to be grouted when done but its kind of pricey. Any suggestions would be greatly appreciated. THX!!!
tandj1997 is offline   Reply With Quote
Old 03-11-2011, 05:26 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You are probably referring to Snapstone.
It really doesn't cost any more than any other type tile.
How about a nice new shiny vinyl.
XXX
Old 03-11-2011, 06:17 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
Duraceramic is popular.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-11-2011, 06:27 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I was hesitant to mention that stuff - gives me chills.
XXX
Old 03-11-2011, 06:37 PM   #5
Rewards Points: 146
I didn't say it is good, I said it is popular.
Old 03-15-2011, 09:55 AM   #6
Well if I do decide to tile would I be able to go right over the existing floor, I do I need to put something down first? The floor is pretty level and I would only have to rent a wet saw. It looks pretty easy on the DIT Network As long as I work with a small piece of floor at one time and use my spacers I should be ok right?
Old 03-15-2011, 02:05 PM   #7
If the floor is level and smooth you can put laminate over it. Laminate is easy and fast and if you get tired of it, it's easy to remove too.
pyper is offline   Reply With Quote
Floor Drain Cover - Advice? globus999 Plumbing 2 07-23-2010 10:40 PM
Painting linoleum floor? Shadow662 Painting 4 11-20-2009 11:21 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
