What Would Be The Best Direction For My Laminate Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 10:12 AM   #1
Question
What would be the best direction for my laminate flooring?
I would like some opinions from some of you other, probably more experienced DIY people out there. I am installing very nice Pergo laminate flooring throughout my entire house. Because of the length (46 feet), I have to use a spacer going into the last bedroom. Naturally, the boards are running lengthwise down the hall. However the back bedroom is an obvious rectangle with the length of 13.5 feet going the other direction. The width is only 9 feet, 8 inches. However, there is a small entry section going into the room (past the door and created by an adjoining bedroom's closet)that is only 3 feet wide by approx. 2 feet deep. I think this would look odd having the laminate run side to side in such a short space. So, I am in a quandary whether to start the laminate in this room running the same direction as the hall laminate which would look good from the hallway perspective, or to run it the length of the room which would look much better from the overall room perspective. This, of course, would all be on the other side of the spacer. Any helpful ideas out there? Dotrn
dotrn is offline   Reply With Quote
Old 06-29-2009, 01:01 PM   #2
General Contractor
You should run wood or laminate flooring perpendicular to the floor joists. If run horizontal you may experience dips in the finished floor. Also check for low spots and fill with self leveling concrete (you can find it in the tile section of the home centers). If you do decide to run horizontally to the joists it is a good idea to beef up the sub-floor with another layer of plywood run perpendicular to the existing. I would also recommend gluing and screwing this layer down.
ARI001 is offline   Reply With Quote
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 12:04 PM
Laminate on side of steps and direction 83trekker Flooring 4 02-20-2008 03:42 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 09:01 AM
