What Wood Subfloor Do I Need? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 08:50 PM   #1
What wood Subfloor do I need?
Hello all,
I'm replacing an old laminate and carpet flooring section of my home with all new laminate. Under the existing was 3/4" tongue/groove plywood that was screwed directly into the concrete slab.
The concrete slab is mostly level, bit higher on one side of the kitchen area...
Do I just replace it with the same 3/4" tongue/groove plywood > liquid nail > and screw it down... or use something else?
ALSO, because this is in a kitchen and dining room, in the kitchen area by the sink, should I use clear silicone on the laminate tongue when I goto install it so that no water penetrates it?
Thanks!
Integraoligist is offline   Reply With Quote
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
