What Is The White "paint" Under My Capet Pad? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-04-2014, 04:01 PM   #1
Rewards Points: 37
what is the white "paint" under my capet pad?
my house is on a concrete slab. I am tearing up the carpet and carpet pad and noticed the concrete is painted white. is this some sort of latex coat? i am going to tile the room so i will have to scrape it all off.
joshik is offline   Reply With Quote
Old 03-04-2014, 04:09 PM   #2
Rewards Points: 734
Possibly used as a moisture barrier to protect the carpeting, Concrete will leach moisture up through itself, from the surrounding soil. Especially if you are in a moisture prone area.
ED
de-nagorg is offline   Reply With Quote
Old 03-04-2014, 04:27 PM   #3
Rewards Points: 37
i was thinking that. i live in socal and it doesnt rain here much (hence our major drought) but this room has an exterior wall and a lawn just outside that gets watered.
would i have to lay some sort of moisture barrier before i tile?
Old 03-04-2014, 05:40 PM   #4
Rewards Points: 12,818
No, but the old white stuff needs to go.
If I had to guess I'd say someone tried using Dri Lok to stop the moisture.
Slabs can not be water proofed from the top side.
de-nagorg (03-04-2014)
Old 03-04-2014, 05:43 PM   #5
Rewards Points: 734
Your mastic or thinset should be sufficient, and yes the "white stuff", has got to go before the mastic will adhere.
ED
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
basic white paint mcl6302 Painting 6 10-11-2010 05:58 PM
turning white to antique white rustyedge Painting 6 10-01-2010 01:08 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
