What To Use As Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2006, 10:03 AM   #1
What to use as underlayment?
OK, tearing into the bathroom...pulled the linoleum (three layers worth ) and found the flooring is particle board (or chip board to some)...it has been wet a couple times and has a couple soft spots near the edges (nothing structural)...So, I'm going to remove the soft spots and fill with wood putty...
Now, I want to use self stick tiles...and since the flooring is rough due to it being particle board and from the mastic used for the linoleum, I want to use a underlayment...but what to use? I know that 1/8" or 1/4" masonite is common...but what about a wet environment such as a bathroom...especially since there will be seams every 12"s from the selfstick tiles...
Is there a water resistant or waterproof option I can look for??
Thanks,
steve
SDeeter19464 is offline   Reply With Quote
Old 05-12-2006, 09:38 PM   #2
Adhesive tiles wont last too long in that kind of enviroment.
lxdollarsxl is offline   Reply With Quote
Trafficmaster Allure - Underlayment? HuskySkull Flooring 47 06-11-2014 04:04 PM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Underlayment for laminate dm62 Flooring 3 04-02-2005 10:56 AM
