What Is Under My Carpet? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 10:49 AM   #1
What is under my carpet?
I want to remove my carpet and lay down some sort of laminate flooring. So my questions are, is there hardwood under every carpet in every house? If not what are some of the different things that could be under it? Just a little more info...the original house is about 50 years old. However, this particular part of the house is only 17 months old.
My last two questions are, how do I lift the carpet to check what is under it and to pull it up to change it? Finally, is changing the flooring difficult? Both my husband and I are complete idiots when comes to anything that requires a little handy work.
mrsvargas1976 is offline   Reply With Quote
Old 03-19-2011, 10:54 AM   #2
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
Usually the carpet is only held down by a tack strip around the perimeter of the room. I would go to a corner and gently pull up the carpet and see what is underneath. If it's not hardwood then put it back down and tuck it back under the baseboard. My guess would be that if this is a new addition that it would just be plywood subfloor underneath.
danrb007 is offline   Reply With Quote
The Following User Says Thank You to danrb007 For This Useful Post:
mrsvargas1976 (03-19-2011)
Old 03-19-2011, 11:25 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
If you are lucky, it's plywood. More likely it's OSB or particle board.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 03-19-2011, 01:26 PM   #4
do you have a vent in the room that you can pull out and look at what is under it without touching the carpeting. If you lift the carpet you may loose the stretch of the carpet. that may not matter thou if you are looking to replace it soon.. if not don't do it.
IceT is offline   Reply With Quote
The Following User Says Thank You to IceT For This Useful Post:
carpet to laminate transition 8roty Flooring 3 11-08-2010 06:41 AM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 01:23 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
