What Type Of Subfloor For Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 06:43 PM   #1
what type of subfloor for Hardwood
Hi,
I am installing 3/4" Solid Hardwood into my living room. I've pulled the carpet and am beginning the prep work.
Some installers say that I can install directly on to the OSB Floor and not install subfloor. is this true? Should I lay down a subfloor on top of that prior to installing my hardwood?
What type should I use? how thick should it be?
Digital Mike is offline   Reply With Quote
Old 07-18-2013, 06:45 PM   #2
General Contractor
CENTERLINE MV's Avatar
the OSB on top of your floor joists IS your sub floor. Make sure it's secured properly and thick enough for your joist span to prevent sagging. Re-nail or screw if necessary.
CENTERLINE MV is offline   Reply With Quote
Old 07-19-2013, 03:39 PM   #3
Rewards Points: 274
I agree with this guy, thick sub floor is essential part for top flooring.
alexjoe is offline   Reply With Quote
Old 07-22-2013, 02:23 PM   #4
Still Decompressing
Rewards Points: 273
Are you agreeing with the original posters advisor? Or poster #2??
I am in the exact same position. Have nearly all my old flooring removed. The original wood floor I am removing was nailed right to the OSB with only tar-paper underneath.
What kind of sub-floor are you recommending??
caveeagle is offline   Reply With Quote
Old 07-22-2013, 06:27 PM   #5
DIY staff
Rewards Points: 7,174
If you have 3/4" osb you can staple or nail right to that---
How was the flooring that you removed? Was it holding well?
I prefer staples ---but never had a reason to fault the cleats---
My flooring guy uses staples and said that demolishing a stapled flood is much more work than removing a floor set with cleats---
Old 07-26-2013, 05:57 PM   #6
Rewards Points: 744
The general recommendation I see from manufacturers is CD Exposure 1 grade plywood or OSB Exposure 1. minimum 5/8" thickness on 16" o.c joists or 3/4" thickness on 19" joists. Always satisfy manufacturer's requirements.
Seattle2k is offline   Reply With Quote
Tags
hardwood , how thick? , subfloor , what type
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 03:35 PM
screw type bulbs. mpj111 Electrical 5 01-27-2009 03:27 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 12:30 AM
Need help with Type T and TL fuses? Fotoguy Electrical 6 03-04-2008 01:08 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
