-   -   what type of subfloor for Hardwood (http://www.diychatroom.com/f5/what-type-subfloor-hardwood-183819/)
Digital Mike 07-18-2013 06:43 PM
Hi,
I am installing 3/4" Solid Hardwood into my living room. I've pulled the carpet and am beginning the prep work.
Some installers say that I can install directly on to the OSB Floor and not install subfloor. is this true? Should I lay down a subfloor on top of that prior to installing my hardwood?
What type should I use? how thick should it be?
CENTERLINE MV 07-18-2013 06:45 PM
the OSB on top of your floor joists IS your sub floor. Make sure it's secured properly and thick enough for your joist span to prevent sagging. Re-nail or screw if necessary.
alexjoe 07-19-2013 03:39 PM
I agree with this guy, thick sub floor is essential part for top flooring.
caveeagle 07-22-2013 02:23 PM
Are you agreeing with the original posters advisor? Or poster #2??
I am in the exact same position. Have nearly all my old flooring removed. The original wood floor I am removing was nailed right to the OSB with only tar-paper underneath.
What kind of sub-floor are you recommending??
oh'mike 07-22-2013 06:27 PM
If you have 3/4" osb you can staple or nail right to that---
How was the flooring that you removed? Was it holding well?
I prefer staples ---but never had a reason to fault the cleats---
My flooring guy uses staples and said that demolishing a stapled flood is much more work than removing a floor set with cleats---
Seattle2k 07-26-2013 05:57 PM
The general recommendation I see from manufacturers is CD Exposure 1 grade plywood or OSB Exposure 1. minimum 5/8" thickness on 16" o.c joists or 3/4" thickness on 19" joists. Always satisfy manufacturer's requirements.
