What Type Of Stainable Concrete Filler Should I Use? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 05:22 PM   #1
Rewards Points: 77
What type of Stainable Concrete Filler Should I Use?
I'm planning to dye or stain my 85 year old basement concrete floor. I rented a grinder last weekend and did a decent job smoothing it. There are a few unsightly pits and holes that I would like to fill prior to dying the surface. I want to use a filler material that will still absorb the concrete stain when I apply it so I don't want to use anything non-porous or moisture resistant like an epoxy filler. I was thinking about just getting a tub of premixed concrete from HD. I have used it before and it's nice to work with and is convenient for filling small spaces since I don't have to waste a lot of material mixing large volume of dry mix. I would like to know if there are any other recommended stainable compounds for filling small pits and cracks in concrete.
Thanks in advance, VC
vcheez is offline   Reply With Quote
Old 01-13-2012, 12:41 PM   #2
Rewards Points: 77
Hey Guys,
I'm just bumping my thread since I have not received any replies yet. I'm looking for some advice about concrete fillers that will absorb stain
Old 10-08-2013, 04:23 PM   #3
Any viable solution yet? Looking for the same!
Hi there. I wish I had an answer for you. I'm looking for the same. Do you have any viable solution yet? Let me know if you find anything out anyone. I'm currently working on a similar project.
njebudalla is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
