What Type Of Plywood To Get? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 01:29 PM   #1
Rewards Points: 18
What type of plywood to get?
Can someone recommend what type of plywood to get for this situation:
I have a power cage in the garage. At any point in time the power cage may be loaded with up to 500lbs of weight. The biggest issue is the weights will come into hard contact with the ground(deadlifts). My goal is to have the power cage and my weights not touching the garage(incase of spills or flooding) and to protect the garage floor. I do have rubber mats to place on top of the plywood, I just didn't realize there are 1billion different types of plywood.
My plan is to get 4 pieces of 4x8 plywood. 2 layered down side by side and the other 2 layered on top going the other way. 1/2 inch Rubber mats on top.
Photo of a power cage
peequi is offline   Reply With Quote
Old 02-23-2012, 06:08 PM   #2
Here is what I would recommend. http://www.homedepot.com/Lumber-Comp...&storeId=10051
This plywood should stay fairly flat and has water repellant so humidity from the concrete should not affect it.
MNsawyergp is offline   Reply With Quote
Old 02-23-2012, 06:22 PM   #3
Rewards Points: 13,270
I would use 3/4" Advantec T & G subflooring.
JetSwet (02-23-2012)
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 01:05 PM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 05:21 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
