What Type Of Grout And Sealer Is The Best For Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 06:01 PM   #1
What type of grout and sealer is the best for flooring
What type of grout is the best for ceramic flooring and sealing it? I didn't know when I put down the grout I needed to pile on the sealant so the grount is stained and looks pretty bad.
HELP
skullface is offline   Reply With Quote
Old 06-01-2009, 12:36 PM   #2
onlinehandyman
Rewards Points: 125
Hey Skull,
I'm actually here with a very similar question. I have always been under the impression that some - not all grout sealers turn the grout a slightly different color. I was hoping someone could shed some light on this for us as well.
Onlinehandyman
onlinehandyman
onlinehandyman is offline   Reply With Quote
Old 06-01-2009, 09:38 PM   #3
My brother in law told me he had to really soak his grout with the sealant and let it soak in until it couldn't hold anymore (told me a little too late) and not to use white, to get a darker color so it doesn't show dirt.
Old 06-01-2009, 09:40 PM   #4
I guess I used the wrong kind of grout or did it wrong because mine cracked real bad and broke apart so I tried replacing the worst parts with a different kind of grout which I didn't seal correctly so now I have 2 kinds of grout, neither of which look very good, and a horrible time trying to get it up so I can fix my broken tile and redo the grout correctly.
A handyman I am not.
Old 06-01-2009, 10:00 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 412
Sounds like you have more problems than the grout. Wrong grout and not sealing does not cause tiles to crack.
Rather then letting us guess, why don't you tell us what type of tiles, the width of the grout joints, the kind of grout you used, and what you set it with and over what?
Jaz
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Sealing grout for outdoor granite sidewalk TVM Tiling, ceramics, marble 17 02-16-2009 07:09 PM
What works and what doesn't to clean grout? groutresearcher Flooring 2 09-04-2008 10:49 PM
wet space grout sealer help irlizard Flooring 2 08-15-2006 05:13 PM
