Old 02-22-2009, 08:46 PM   #1
DIY Expert in Training!
What type of concrete?
I need to pour a small step in order to level a transition from family room to new office. My plan is to cover over the rough concrete in the picture below and make the step about 1 1/2" high. Once dry I will seal and put a wood step over it as the transition.
First, what type of concrete do I use to make sure it is secure.
Second, what tips, tricks, concerns should I watch out for?
Thanks,
Kevin
gone_fishing is offline   Reply With Quote
Old 02-23-2009, 07:15 AM   #2
Remodeling Contractor
An 1 1/2" step is a no-no. Bond the old cement after cleaning and drying. Make a plywood form and mix a bag of cement. No special cement is needed. but a step must be at least 6 1/2" and no more than 8 1/4"
Old 02-23-2009, 07:27 AM   #3
Bob...it's not really a step. What I am doing is leveling the transition with the family room. It's about 2" total so the concrete would be about 1 1/2 with a plank of wood on top to finish it off.
Old 02-23-2009, 08:51 AM   #4
Still working on this? Protect all the wood (jams) from contact with the concrete with some tar paper. Nail or screw with tapcons a board at the lower end to make a form and just use some self leveling compound. Be sure to use the primer first.
Old 02-23-2009, 09:05 AM   #5
I didn't think you could use the self leveling that thick. This is part of a pretty big project. I've done all of the work myself except for 1 day of help with drywall.
Old 02-23-2009, 09:12 AM   #6
look at the directions on a bag of it. 2" should be within limits...
Old 02-23-2009, 10:21 PM   #7
I'm no expert, however I have recently poured my own threshold.
I got one bag of portland cement and one bag of sand. I experimented a little.
The mix I liked was 3 parts portland to one part sand mixed with an admixture.
It seems to have worked out.
I made a mold/stopping point on both sides of the door with the proper slant and troweled accordingly. I also mixed the concrete thick so it would not want to level so much and knocked it a few times with a rubber mallet to remove air bubbles.
The finish sanding will be minimal after full curing.
That was my process. Good luck. My threshold goes to outside so I will seal it as well.
drillbit is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
