Old 03-19-2009, 07:30 PM   #1
Question What type of adhesive should I use to glue down accoustical cork to a concrete floo
I'm installing an Armstrong locking natural hardwood floor (EL5MB12NALG). I have to adhesive bond acoustical cork to the concrete floor then glue down the planks to the acoustical cork. Can anyone tell me:
* What Armstrong adhesives will work for this application? That is, the adhesive for the cork to the concrete, and the glue for the planks to the cork?
* How do you prep / clean the concrete floor prior to applying the adhesive?
* Does the adhesive need to cure before you glue the planks to the cork?
Please help. Thank you.
Fixitgeorge is offline   Reply With Quote
Old 03-20-2009, 07:56 AM   #2
poppameth's Avatar
Why are you gluing this down? This is designed to be a floating floor. Here is the installation guide. I skimmed it briefly, not having worked with this particular product before, but I saw no mention of gluing it down. I'll look at the guide more closely when I have the time.
http://www.armstrong.com/content2/resam/files/24785.pdf
poppameth is offline   Reply With Quote
Old 03-20-2009, 09:54 AM   #3
Commonly recommended adhesives for installing cork are water-based contact cement adhesives which are known to be amongst the most reliable and effective. Cork is a porous material and allows the water in the adhesive to evaporate, creating a strong bond. Moreover, contact cement is easily available in nearly every hardware store.
Dana
Dana11 is offline   Reply With Quote
More On This Topic
Now I'm going to show you how to replace a water key cork. This one has fallen out, that's usually the case with most of them, otherwise a true sign that you need to replace your water key cork is, it will have a great big indentation in the cork. Or you... Read More »
Cork, a renewable resource, comes from the bark of the Mediterranean cork oak tree. Every 9 to 10 years, cutters carefully harvest cork bark without harming the host trees. Through a process of grinding and baking, craftsmen create cork flooring sheets... Read More »
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
The biggest challenge in decorating your home is finding out what really is good. There are a number of products on the market that are extremely toxic and in my mind should not be sold to the public. Products that they know have formaldehyde and all... Read More »
Installing new vinyl flooring is an inexpensive way to improve the look of a room, especially kitchens, bathrooms and laundry rooms. You can save quite a bit of money by installing the vinyl floor yourself. The most difficult step is applying the... Read More »
What type of concrete? gone_fishing Flooring 6 02-23-2009 11:21 PM
What type of adhesive for engineer wood floor? bobbo Flooring 2 02-01-2009 03:36 PM
Which type of adhesive or thinset should I be using? yummy mummy Flooring 3 01-02-2009 12:45 PM
Cleaning adhesive from a concrete subfloor sparinaa Flooring 2 09-16-2007 12:21 AM
Adhesive removal from concrete sod Flooring 3 04-02-2007 10:41 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
