Old 08-27-2010, 10:28 AM   #1
Post
what thickness of ply to use on bathroom floor ready for lino?
ive recently had a bad leak in the bathroom, and the insurance are dealing with all the bad stuff, but the mrs wants cushion floor down afterward, and i know you need to put plywood down over the floorboards to give it an even surface, but i dont know what thickness to get or how to put it down? we have a company coming in to lay the lino so i dont have to bother with all that either, its just the ply sub floor!!!!! help please!!!!
dondin is offline   Reply With Quote
Old 08-27-2010, 10:41 AM   #2
You can use 1/2'' - 5/8'' plywood. Screw it down every 6'' and run a construction adhesive on the floor joist (screw and glue) and you should be set…
epson is offline   Reply With Quote
Old 08-27-2010, 10:44 AM   #3
floor_whore
Send a message via Yahoo to Aaroncarpet
if your plywood is in good shape you can install 1/4" brazilian luan.. it has a smooth top for sheet goods. it comes 8x4 like plywood..you have to "butter" the joints and should be stapled or ring shank nailed every 4-6"s and more on the joints...
Aaroncarpet is offline   Reply With Quote
Old 08-27-2010, 01:50 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Luan is not a warrantied underlayment for most vinyls. It should be stapled, not nailed.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 08-27-2010, 05:50 PM   #5
floor_whore
If not warrantied and you use plywood, you will have to still skim coat, better to use hardy backer or similar product for a smooth finish plus 4x4 , easier to handle.
Old 08-28-2010, 08:23 AM   #6
Doer of Many Things
poppameth's Avatar
You should be using a good birch plywood for this. 1/4" Ultraply is what we usually use.
poppameth is offline   Reply With Quote
Old 08-28-2010, 11:55 PM   #7
Go 5/8" plywood and install just like epson says and remember to install the plywood with the grain perpendicular to the joists.
gjjr2001 is offline   Reply With Quote
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Soundproofing a Bathroom jbitt Remodeling 8 01-29-2010 11:53 AM
Granite Thickness in Bathroom Kyle Remodeling 5 01-24-2010 08:11 PM
