What Size Trowel For 20" Tiles? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-05-2007, 07:09 PM   #1
kemerick's Avatar
Rewards Points: 87
What size trowel for 20" tiles?
I am laying 20" porcelain tiles on top of Hardibacker and I am wondering what size trowel I should use? 1/2"? 3/8"? 1/4"?
Or does it really matter? From what I have read, it all comes down to what provides the best coverage.
The floor is fairly level and I floated some of the Hardibacker boards to make up for the minor low spots. The floor in question is my kitchen:
http://www.emerickdesigns.com/media/.../target43.html
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-06-2007, 12:21 AM   #2
jproffer's Avatar
Rewards Points: 706
I would think 1/4" x 1/4" would be fine. How thick are the tiles?
jproffer is online now   Reply With Quote
Old 10-06-2007, 12:22 PM   #3
kemerick's Avatar
Rewards Points: 87
1/4" thick
Old 10-06-2007, 08:19 PM   #4
jproffer's Avatar
Rewards Points: 706
1/4" x 1/4" is fine. Make sure you get 100% coverage on the tiles. Really that applies to any tile, but especially 20 inchers.
Old 10-06-2007, 09:32 PM   #5
If the tiles are ceramic 1/4" notched is cool. Otherwise, you may need a 3/8" if the tiles are rough like a slate. The trick here is to "butter" the back of the tile just before you set this into the thinset or mortar. This will greatly improve and help insure the bond without any voids. You can also maniplate the height of the trowel by adjusting the angle of contact. This will allow you to aquire a uniform "setting" so that you won't have to clean out nearly so much thinset between the joints.....
RemodelMan is offline   Reply With Quote
Old 10-07-2007, 02:34 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 288
I can't imagine a 20x20 tile being only 1/4" thick. I bet it's closer to 3/8" or thicker. Even most standard 12" are 5/16". Regardless of that, the texture of the backs is more important when choosing a trowel, that and the flatness of the floor. I would never use such a small notch. My standard trowel for anything around 12-13" is 1/4x3/8x1/4. On 20" I would probably choose 1/4x1/2 or 1/2x1/2. You want at least 85% coverage.
What kind/type of thinset are you going to use? It should be a medium bed mortar. Tell us what you've chosen. I hope your floor is almost as flat as your kitchen table with tiles that size. Did you double check the subfloor structure and consult a span chart to see that it'll be stiff enough for tile?
Jaz
JazMan is online now   Reply With Quote
Old 10-07-2007, 08:13 AM   #7
JazMan, makes a very important point. Your subfloor needs to be well supported without any detectable flexibilty. Otherwise, you risk poping or at least cracking grout joints and eventually loose tiles. 1" solid substrate is the industry minimum, Note: minimum. Also be sure to fill all substrate/subfloor joints. BTW these joints don't have to be sanded.
Old 10-09-2007, 08:42 PM   #8
Jaz
I agree. The key if 100% transer from floor to tile.
flooring dude is offline   Reply With Quote
Old 10-09-2007, 10:29 PM   #9
kemerick's Avatar
Rewards Points: 87
The subfloor is good. I pulled all the 1" x 6" planks, added supports in areas where needed and put down 3/4 tounge and groove plywood wthe 3" screws and I also used 3 1/2 boxes of Liquid Nails subfloor glue. The I used a 1/4" trowel to set the 1/4" Hardibacker board.
I ended up using a 1/2" x 1/2" trowel and after pulling up a couple I was getting about 90% coverage since you guys made me all paranoid :-)
The tiles are all very close to .280". I went back and measured them with my micrometer
Here is the latest gallery from working on the house this past weekend. The first couple are from a 1.3 MP camera phone so the quality is not great, but the rest show the floor tiles going in.
http://www.emerickdesigns.com/media/..._05/index.html
Thanks again for all the advice...
Old 10-09-2007, 10:31 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 288
Thanks. While 100% would be nice, it's not necessary for interior tile work. I think the standard is about 85% for floors. Outdoor work requires 100% to avoid place for water to collect, freeze, then cause trouble.
While I was typing, you were posting....Great, the new info sounds good to me.
Jaz
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
