- What Size Backer Board Needed To Make Smooth Transitions - - Flooring - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 03:55 AM   #1
- What size Backer board needed to make smooth transitions -
I am looking to do transitions without the need of a strip in a gut job right now the heighth of the 2 bathrooms is as follows.
I need to know what I need to put on each side of the transition to make the smoothest possible transition.
Bathroom #1
EVEN Hallway ---- Bathroom. (Current)
Hallway has existing hardwood floor (very bad condition) which will have 3/4" 5 inch Natural Hickory added to it and the bathroom is even with this right now with 3/4" Advantech Subflooring installed.
What will make the best transition for me? 1/2" or 1/4" backer board and then tile.
Bathroom #2 Level Right now. - Master Bedroom ---- Master Bath
Master Bath will get carpet and pad. Same question.
Thanks for any help or ideas for the smoothest transitions without the need for a transition strip. First time doing this type of project myself.
nohoch is offline   Reply With Quote
Old 04-23-2013, 09:04 AM   #2
Rewards Points: 12,876
I personaly would not be laying new hardwood over any old flooring in poor shape. Flooring that wide should be glued down and trying to keep it stuck to the floor if it has low spots, cupping water damage is not going to work out.
It's pretty common to have a small transition from a tiled floor to the other types of flooring.
Old 04-23-2013, 02:08 PM   #3
Rewards Points: 744
Bathroom #1
First off, your description is hard to follow.
Second...you're really going to put carpet in your master bathroom?
Seattle2k is offline   Reply With Quote
Old 04-23-2013, 04:56 PM   #4
Sorry for the bad description I meant Master Bedroom would get the carpet, and wanted to know how to keep that transition as smooth as possible.
@joecaption the hardwood thats there is in poor condition not unlevel and warping and such just unsalvagable with some stains and rooms got changed around so the flow wouldnt work either.
Old 04-24-2013, 12:48 AM   #5
Rewards Points: 744
Right, which is why the old hardwood should be removed first.
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 08:22 PM
Backer Board Around Tub Deteriorated. devnull88 Plumbing 2 05-18-2011 04:56 PM
cement backer board or not? Jroberts8192 Tiling, ceramics, marble 4 04-18-2011 09:27 PM
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
