What Should I Do Now With My Subfloor? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 09:23 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 232
The following is the best choice they carry. How come the only choice is orange? http://www.homedepot.com/Lumber-Comp...atalogId=10053
Jaz
Old 12-13-2011, 10:59 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Doesn't make sense that HD would build a store where there was no source before. Hell, there wouldn't be anyone for them to run out of business!
Old 12-14-2011, 09:49 AM   #18
HD because I probably don't know any better. OK, the room is 6'2" x 7' like in the first picture of this thread. 6'2" running horizontally, 7' running vertically in relation to your screen, joist are every 24" running vertically in relation to your screen.
Since the plywood is 4x8, I could either cut 2 pieces and run them vertically or horizontally. Does it matter which way I lay down the plywood. I was thinking horizontally because they would run perpendicular to the joist, therefore touch more joists & provide more support. But some of recommended vertically because they think it is an easier cut.
If I run vertially the shower pan area to the other side of the wall would be one long board. Horizontally, would just cover over 4" over the shower area.
Mjolnir is offline   Reply With Quote
Old 12-14-2011, 08:38 PM   #19
Tileguy
JazMan's Avatar
Rewards Points: 232
Subfloor and underlayments ALWAYS must be installed with the face grain perpendicular to the joists. The direction of the face grain is the strongest orientation of the panel.
Jaz
Old 12-16-2011, 10:34 PM   #20
Thanks, didn't know that. I have a question about the toilet flange. It sits about 1.25" above the current subloor. I have no plans to remove it as it looks like a difficult job. How high should the toilet flange be in relation to the top of ceramic floor, below, same or above level?
when i removed the tiles it was same level as the ceramic floor, then some contractor says it has to sit above. if it this is the case i have less room to play with.
construction adhesive 0.0625" + plywood 0.5" + mortar 0.125" + backer board 0.25" + thinset 0.125" + ceramic 0.25"= 1.31"
1.31" that would mean the toilet flange is below the height of the ceramic tiles. is this going to be a problem?
also, what is your backer board of choice?
Old 12-16-2011, 11:55 PM   #21
Tileguy
JazMan's Avatar
Rewards Points: 232
Ideally the bottom of the flange sits on the finished flooring. But that can vary and we often work with what we've got. I've done floors where the flange was 1/2" below the tiles. They make extenders or you can use thicker or even two wax rings.
Let me see about these figures you've posted.
Forget the construction adhesive, you do not use construction adhesive when installing underlayment on the subfloor.
!/2" ply is not .50. It's 1/32" under !/2" or 15/32".
The cured thin set under the backerboard will not be 1/8" thick. Maybe 1/16".
Most 1/4" backer boards are 1/4". What brand are you using?
!/8" for the tile-bond thin set is close, (probably 3/32"), I doubt the tiles are only 1/4". They are most likely closer to 5/16" or more.
My preference is Ditra, but for a small bathroom whatever is handy is OK.
Jaz
Old 12-17-2011, 12:01 AM   #22
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually...that's all workable. Not to worry. Get your tile in and that will change the variables to actuals then you will see what else needs to be done, but you're in good shape.
XXX
Old 12-17-2011, 11:03 AM   #23
I will be using durock next gen. Where the wall that comes out to enclose the shower, from that wall to the edge of the opposite wall I want that to be the end of the shower border. But if I erect a border and want a glass door sitting on top, I only have ~1 inch width for the glass door to sit on.
I can make it wider in the direction away from the shower drain but the border would not be flush and ppl could ram their toes inadvertently. I could make it wider in the direction of the shower drain but would lose shower floor space n have an asymmetrical shower bed.
So is a 1 inch wide elevated border enough for a glass door to sit on?
Old 12-17-2011, 11:54 AM   #24
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No it is not.
XXX
Old 12-17-2011, 12:47 PM   #25
Busy DIYer
picflight's Avatar
Rewards Points: 150
Nir, post pictures as you go along, I am watching how you are dealing with the toilet flange.
picflight is offline   Reply With Quote
Tags
ceramic tile , plywood , subfloor , water damage , wire mesh
How should I reinforce this subfloor? NewHomeDIYGuy Tiling, ceramics, marble 35 12-05-2011 11:01 AM
How to flatten subfloor hump? loftezy Flooring 9 11-15-2011 01:53 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
