What Sander Is Best? Vibrate Or Drum - Flooring - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 12:49 PM   #1
What sander is best? Vibrate or drum
I'm preparing to stain and finish a new just installed oak hardwood floor. I was told that a vibrating sander was better to use than a drum because being my first time it was less likely to damage the wood. Will it do as good job and would you agree. I would appreciate any and all advice to make this job easier but right.
hebrewdiver is offline   Reply With Quote
Old 10-11-2009, 06:48 AM   #2
Rental places have user friendly disk sanders, a much better choice over drum sanders for the novice. One heartbeat is enough to ruin a floor with a drum sander.
Old 10-11-2009, 02:49 PM   #3
Rewards Points: 266
If it is new flooring it probably doesnt need much sanding to make nice and flat. I have used both. I prefer drum sander for refishing and getting rid of old finish and scrathes quickly. A drum sander can do a lot of damage if you are not careful. For new flooring it probably doesnt need much sanding. I would go with a vibrating sander (orbital) I put in 1000 sq ft of oak flooring and my 14 yr old son did the sanding in a few hours. Unsupervised---thats how easy it is.
another nice thing about the orbital is they go right up against the wall. the drum sander you have 8-12" you will have to finish with a edger. running the risk of creating a noticeable line or snipe where you stopped with the drum sander.
Here's a link to his handywork.. new wood flooring
good luck of course post pics when you are done
What have I done is offline   Reply With Quote
Drum trap, best to replace them? diymonkey Plumbing 4 06-04-2009 08:14 AM
Belt Sander? or other type... KUIPORNG Tools 7 04-18-2007 02:51 PM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 09:44 PM
