What To Put Under An Area Rug? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 09:52 PM   #1
Rewards Points: 1,088
What to put under an Area Rug?
What's the best thing to put under an area rug for cushioning and to keep the rug in place?
I've heard that carpet companies have some sort of felt that is better than a carpet pad (1/4" or 3/8") because it doesn't stick to hardwood floors.
handy man88 is offline   Reply With Quote
Old 04-24-2011, 11:30 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You need rug pad. There is a heavy synthetic jute pad with a rubberized back on it that provides a good firm padding with great slip resistance. Ours is called AnchorGrip, but that is a private labeled name for the company we buy it from.
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
handy man88 (05-04-2011)
Old 04-24-2011, 11:55 AM   #3
Too Short? Cut it Again!
You wouldn't want to use it on an antique oriental rug but there is also a latex compound you can paint on area rugs. It will not add much cushion though.
The area rug padding mentioned is probably your best bet. I've never found anything that does not eventually react with floor finishes though. You can usually buff it out when done with the rug. Also, depending on the UV protection on the floor, don't be surprised at the difference in color when you pull the area rug up a few years down the line---especially if your floor has a darker color and stain to it.
And finally, be sure to pull the rug up periodically and vacuum underneath it. In even the cleanest of houses you will surprised at the amount of grit that can sneak under a rug and etch away at the floor is you grind it around walking on it.
Old 04-24-2011, 07:53 PM   #4
Do rug pads only secure the rug in place, or does it provide cushioning also?
Old 04-24-2011, 07:55 PM   #5
You're right about the grit.
Where my rug will be located, the living room does not get direct sunlight as it is north facing.
Old 04-24-2011, 08:56 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
I just sweep my dirt under the rug.
Andy.
AndyGump is offline   Reply With Quote
Old 04-25-2011, 05:46 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It provides padding as well as slip resistance. But it isn't a squishy pad. It's very firm compared to a carpet pad.
AndyGump (04-25-2011)
Old 05-04-2011, 04:09 PM   #8
How much is the charge per square yard?
Old 05-05-2011, 05:50 AM   #9
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The stuff isn't cheap. We generally sell it around $8.00 a SY, but costs fluctuate on padding all the time. It could be a lot different from whoever you buy it from locally.
Darkling Designs
area surrounding top of shower stall mustangsalee613 Kitchen & Bath Remodeling 1 03-20-2011 10:08 PM
What to install first: 8x8 post OR paver area cgilbert Landscaping & Lawn Care 1 03-18-2011 06:21 PM
Outdoor Seating Area JackOfAllTrades Landscaping & Lawn Care 10 02-05-2010 02:01 PM
Sheet rock repair/Lower Bay Window area VEEDUB General DIY Discussions 2 10-03-2009 08:44 AM
small area of rotten wood on deck hohadcr Carpentry 1 09-10-2009 04:11 PM
