What Kind Of Water Sealer For Concrete/brick? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 09:43 PM   #1
What kind of water sealer for concrete/brick?
I have a concrete porch with brick facing. I've seen other peoples homes built this way and the mortar joint between the concrete porch and the brick facing is badly cracked, apparently from rain/freeze cycles. What kind of sealant works well? Also, is there anything I can mix or apply that will keep the surface from being slippery when it's wet? Mix sand with the sealant maybe? Thanks.
higgins is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
