What Kind Of Vapor Barrier For Hardwood? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 08:26 AM   #1
Rewards Points: 133
What kind of vapor barrier for hardwood?
Happy New Year!
I have a question about vapor barriers. We are installing 3/4" x 3-1/4" oak over 3/4" plywood and need to select a vapor barrier. It's a 30 y.o. home build over a crawl space. Southern Illinois - lots of t-storms in the spring.
What would be the best barrier? I have some floor leveling to do and suppose I will start with 30 lb felt for the big gaps. Okay? I saw a cool YouTube video where the guy was using "door skin" but have been unable to find it anywhere.
Went to LL yesterday and the sales guy said that felt was "old school" and I should use their Eco Silent Sound HD or a silicone barrier.
So, what do you experts say? Felt? Red Rosin? Silicone? Waxed paper? Saran wrap?
Thank you very much!
MurphyMan is offline   Reply With Quote
Old 12-31-2011, 08:33 AM   #2
MarginallyQualified
Rewards Points: 2,464
If you're going to install a vapor barrier it really belongs below the subfloor along with the insulation; not above all of that. Above the subfloor (in the heated space)... old school rosin paper should be plenty enough to install your new flooring with.
hth
Old 12-31-2011, 09:04 AM   #3
Rewards Points: 133
Maybe vapor barrier is the wrong term? The house has backed fiberglass insulation between the joists, held up with chicken wire.
I am trying to choose a good interface between the oak flooring and the plywood. I am looking at a publication from the National Wood Flooring Association that says "Do not use common red rosin or building paper which is not asphalt saturated. They are not vapor retarders as their perm rating is far greater than 50".
Old 12-31-2011, 09:28 AM   #4
MarginallyQualified
...the National Wood Flooring Association that says "Do not use common red rosin or building paper which is not asphalt saturated..."
That describes tar paper.
Old 12-31-2011, 09:57 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Imagine him saying that when he had another product to sell to you?
XXX
Old 12-31-2011, 03:00 PM   #6
Registered User
Rewards Points: 5,520
Cupping of wood floor, need input
Gary
What kind of valve is this? mwong Plumbing 10 12-06-2011 11:33 PM
what kind of wye do I need? graysqwrl Plumbing 6 06-22-2011 04:23 PM
Painting Baseboards(does it matter what kind?) SabineTLK Interior Decorating 12 02-06-2011 07:34 AM
What kind of floating floor ? mvesr Flooring 3 09-17-2009 02:59 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
