What Kind Of Uderlayment For Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 02:25 PM   #1
What kind of uderlayment for bathroom
Hi, I just joined the forums, hoping someone can help me out.
I ripped up the vinyl flooring in our bathroom, and there was a few spots where the wood had some moisture in it. I believe it's called "underlayment", the wood that's stapled to the actual rough wood floor (subfloor?).I ripped up all the wood, it was pressed wood, took a while as it came out in chunks due to the staples every 4". The subfloor hasn't sustained any water damage, only a few colored spots that are drying with a fan. My question is, what kind of wood should I use for the new underlayment? And should I lay a vapor barrier in between the subfloor and underlayment? There wasn't any before, but I don't know if this is common practice. I will be putting new vinyl flooring in, for what it's worth. Thanks for any help, and I apologize for my lack of knowledge.
ozweepay is offline   Reply With Quote
Old 04-19-2012, 07:02 PM   #2
Stainless Cable & Railing
Cool
Pressed wood prolly means ply wood. I would go with the same stuff maybe even pressure treated plywood. It'll cost more but last a hell of lot longer.. Not to sure about the vapor barrier, but since its a bathroom I would put it in.
cablerailing is offline   Reply With Quote
Old 04-19-2012, 08:12 PM   #3
Rewards Points: 6,652
Check out Georgia Pacific's Dens Shield & DensGuard. I have used the Dens Shield when I tiled our bath floor, and would not hesitate to use it again. Easy to work with, and no extra tools needed to cut it with, since it cuts like Gypsum board.
Old 04-19-2012, 08:26 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 128
The poster said vinyl not tile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-19-2012, 08:29 PM   #5
Rewards Points: 128
You never use pressure treated wood indoors, the chemicals can cause problems. Use underlayment grade plywood. Stapled just like what you removed. No vapor barrier.
Old 04-19-2012, 08:29 PM   #6
Either one will still work with vinyl. They just need to seal the seams and along the edge where it meets the wall, so that if water does get on the floor, it does not seep through, or get into the material. A whole lot better than using Luann plywood, which is not waterproof.
Old 04-19-2012, 08:42 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
Oz,
I don't know what kind of "pressed wood" underlayment you had, but I doubt it was plywood. Probably OSB or particle board. You should determine what kind of underlayment is recommended by the maker of the new flooring you're gonna install and what's available to you.
And YIKES, you never use pressure treated plywood indoors and especially as an underlayment.
Jaz
Old 04-19-2012, 08:42 PM   #8
Rewards Points: 128
I have been laying vinyl for 40 years and would certainly not use it. Underlayment grade plywood is what all vinyl makers want.
Old 04-20-2012, 06:55 AM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
You can put 1/4" BC ply down as underlayment in this case. Is this sheet vinyl or tile vinyl?
JetSwet is offline   Reply With Quote
Old 04-20-2012, 07:18 AM   #10
Rewards Points: 128
Wouldn't matter on the underlayment. Both use the same.
Old 04-20-2012, 07:42 AM   #11
Pro
JetSwet's Avatar
Rewards Points: 502
Yeah but if it's sheet then use nails instead of screws?
Old 04-20-2012, 08:44 AM   #12
Rewards Points: 128
You should never use screws anyway. It can cause underlayment to pucker. It should be nailed or stapled and stapled is better.
The Following User Says Thank You to rusty baker For This Useful Post:
JetSwet (04-20-2012)
What kind of cable is this? Sith717 Electrical 3 03-10-2012 01:56 PM
What kind of valve is this? mwong Plumbing 10 12-06-2011 11:33 PM
what kind of wye do I need? graysqwrl Plumbing 6 06-22-2011 04:23 PM
Painting Baseboards(does it matter what kind?) SabineTLK Interior Decorating 12 02-06-2011 07:34 AM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
